Question about Fujitsu Siemens AMILO Pro V2000 Notebook
My dvd drive wont work and it doesn't even appear in 'my computer'
    Guru:
  • 597 Answers
Not sure if this is a laptop computer or a desktop but if you can remove the cover of the desktop and check the ribbon and power connectors to your DVD. Failing this your drive is probably bad. But in Vista I have seen CD_ROMs disappear and not been able to reinstall them till I formated and reinstalled Vista. This was an early glitch after Vista first came on the market. One way to test this is to get a bootable CD such as your operating system CD and try to boot from the CD at startup. You may have to go into the Bios and enable your CD as a first option boot up device. If your CD rom is functioning you should be able to boot up from the CD.
Posted on Oct 04, 2009
L305D-S5930 dvd wont burn documents to a dvd disc
You need a program, like nero.
if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer.
the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW.
Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
Jan 30, 2012 | Toshiba Computers & Internet
Compaq Presario F761 Won't recognize DVD RW Drive
First try to load the drivers for the system. Go to dell website provide the service tag and try to install the drivers. If this does not work then take the back up of data and do a simple factory restore.Check out my blog Click here
Kindly click skip ad in the top right hand side to view the article
Nov 27, 2011 | Compaq Presario PCCOM2232US Notebook
I have an emachines e442-v634 w/ Windows 7 Home Premium installed. I tried to remove the bottom cover when the machine stopped working with a blue error screen and, I think a cable or wire got...
I would suggest you check the BIOS if everything is detected properly. Like the hard drive and the memory. If both are working properly and being detected by BIOS properly, then you just might need to install your Windows 7 thru USB. You might need to use a different computer to convert your Win 7 OS DVD to USB installer.
1. Use a different computer w/ DVD 2. Use ISO software to convert the Win7 DVD to ISO 3. Download the converter from this link click here or directly from this link 4. Make sure you have an available USB Flash Disk that has a capacity of 4GB or higher. 5. Once you're done converting the Win7 DVD to an ISO file, use the tool above to convert the ISO file into a USB installer.
This will only work if your hard drive is properly detected. Bootmgr error means 2 things, either the hard drive is not detected or corrupted windows installation.
Hope this helps!
Sep 21, 2011 | Computers & Internet
My iomega prestige 1TB hard drive is not being recognized by my computer. I've already tried with others computers as well, but it doesn't appear to work. The disk is almost full! How can I get...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket
hope this helps
Aug 24, 2011 | Iomega Computers & Internet
I have an acer aspire 5100-4720 notebook. The DVD Drive will not appear in my computer. It shows up sometimes and work perfectly well. But most times, it is missing and does not function. I check the...
Go into system and roll back driver. If this doesn't work, go into hardware and remove it. Restart pc. It should try to reinstall. It may ask for driver. Have it ready.
Apr 24, 2011 | Acer Aspire 5100 4720 Notebook
My Acer travelmate 2492wlmi wont detect or play DVD's/CD's anymore. Even when I go into My Computer the drive (E) does not appear at all. Any suggestions/remedies would be greatly appreciated? Regards
Uninstall the drive and reinstall again. If it still does not recognize it, shut down the system, loose the drive, put on the system and allow it boot without the DVD/CD drive, shut down the system again, carefully connect the DVD/CD drive back into your system and turn your system back on, I believe it should respond by now.
Make sure the DVD/CD drive is well fixed.
Take care
Nov 29, 2009 | Computers & Internet
Dvd writer stopped reading cds even at boot up
try autofixer from microsoft offical page.if doesn"t work
http://www.microsoft.com/downloads/details.aspx?familyid=C680A7B6-E8FA-45C4-A171-1B389CFACDAD&displaylang=en
Apr 26, 2009 | Computers & Internet
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
209 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
