Question about Mabis Health & Beauty
Mabis automaic blood pressure cuff, pressure monitor
Mabis automaic blood pressure cuff, pressure reading fluctuates then shows error
  • Anonymous Mar 13, 2014
    My model 91 seems to work perfectly but it shows an "E" each time even though the cuff blows up.
    Problem Solver:
  • 10 Answers
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com mabis automaic blood pressure cuff, pressure monit - 30ad4e8.jpg
Posted on Oct 13, 2009
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
Why does the cuff on my digital blood pressure monitor pinch
Cuff size, i believe you have to loosen the cuff for your arm size above the elbow
Aug 16, 2014 | Mabis Health & Beauty
What does it mean in the bottom left when it reads 60 then flashes to 01? can't get another reading
The "60" number reading that came onto the screen was your pulse rate. If you can't get the monitor to check your blood pressure again, you may need to replace the batteries, the charge may be too low in them.
Sep 24, 2012 | Mabis ® Automatic Premium Blood Pressure...
The blood pressure monitor reads error 1
make sure you are getting the reader part on the artery just above the bend in the elbow. you may need a new cuff.also make sure it is snuggly plugged into the machine.
Apr 07, 2012 | Mabis ® Automatic Premium Blood Pressure...
The dial reads around 300 when the cuff is uninflated. How do I calibrate the dial?
If the dial reads 300 when the cuff is not inflated, the dial is stuck and there's no way to calibrate it. Try taping on the glass of the dial with your finger to see if it will move. If it doesn't there's really not much you can do yourself, except contact the manufacturer for repair of replacement.
Feb 07, 2011 | Mabis Adult Aneroid Blood Pressure Monitor
Leaking culf
To get a new cuff you need to call Mabis at 800-728-6811
Good Luck
Jul 05, 2010 | Mabis SmartRead Plus Automatic Digital...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Reading are much too high, normal BP is 104/50, monitor reads 130/60
if your arm is too large for the cuff it will read high. most cuffs are made for small framed people. try wrapping it around your lower arm and postion it about 2-3 inches above the wrist. use the wrist to take the b.p.
Jul 27, 2009 | 3M Mabis Adult Aneroid Blood Pressure...
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
Feb 07, 2009 | Omron Automatic Blood Pressure Monitor...
Health & Beauty Logo
338 people viewed this question
Top Mabis Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Dan Webster
Dan Webster
Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
