L20 197 model (celeron) laptop.
Often refuses to boot when power switch pressed.
Replaced motherboard with another good unit. Replaced celeron CPU, and tightened screw correctly. Changed RAM, tested Ok.Installed XP from scaratch all drivers etc worked fine.
Shut down suddenly and won't reboot.
When power switch pressed middle led lights up bot no boot. Soemtimes, the fan whirrs and it boots normally and works normally. I suspect the CPU/socket area. Anybody have any ideas?
Thanks.
    Guru:
  • 597 Answers
In 19 years of working on computers I've seen 1 bad Intel CPU and it still worked it just showed the wrong processor speed. I'd eliminate the CPU being the problem. Generally if you have a bare system with motherboard, ram, keyboard and video and they turn on the system is good. The video may cause a crash if it's bad somewhere in the bootup process going into windows but it shouldn't stop the initial bootup process. The area I would likely suspect is the hard drive. If the arm inside the drive that controls the heads is loose it can cause the drive to read sometimes when cool and then to start slipping and not read when the system is warmer. If you can get into the bios there should be someplace there to check your temperatures and voltages. Those might be a suspect area. If the power supply isn't delivering the proper voltages or the CPU is getting hot could cause problems also. I'd like to hear more about what you're seeing on the screen when this system fails to boot. Does is show the ram countup, system devices and hard drives as detected in the bootup process? Or is the screen just blank. When it doesn't boot does the hard drive light blink continuously?
Posted on Oct 04, 2009
Please help! I have a gateway NE51006u Intel celeron quad core processor N2920 windows 8 laptop. Recently it has been making clicking and notifying me that there is no bootable device. I have tried all...
Solution 1: Instructions for Performing the Power Discharge Procedure (ATX Reset)
Information:
Your computer has no power at all or cannot boot properly. In some situations this can be caused by an external device or an electrical problem. This can usually be solved by removing all external devices and resetting the power supply.
Instructions for laptops:
1. Disconnect all external devices you have.
2. Unplug the power adapter from the laptop.
3. Remove the battery pack from the laptop.
4. Press the power button and hold it for at least 15 seconds.
5. Reconnect the power adapter.
Do not yet reconnect the external devices, they should stay disconnected. Do not yet reseat the battery pack.
6. Switch your laptop on and test if it boots normally and watch if the power LED lights up.
7. If the power LED still does not lights up, continue with the next steps.
8. Disconnect the power adapter from the laptop.
9. Press the power button and hold it for at least 15 seconds.
10. Reseat the battery pack. Do not reconnect the power adapter.
11. Switch your laptop on and test if it boots normally.
Solution 2: Unplug and reconnect System Hard Drive
1. Unplug the power adapter from the laptop.
2. Remove the battery pack from the laptop.
3. Unplug and reconnect System Hard Drive. This is normally accessible by removing a panel at the bottom of the laptop or removing the back enclosure (see User Manual).
4. Reseat the battery.
5. Switch your notebook on and test if it boots normally
Jan 03, 2015 | Computers & Internet
I cannot switch on my laptop. it was working fine last night, but in the morning, my laptop refused to get switched on. nothing happens even if I press the on button, no blinking of anything, no booting,...
You might try to remove and reseat the battery. Jiggle the plug for your charger just to make sure that it can deliver charge to your computer.
You may be needing a new battery for your laptop, especially if the laptop seemed to require more frequent charging.
Look for guidance on your manufacturer's web site about care and charging of your laptop's battery.
Sep 06, 2010 | Computers & Internet
Computer auto power on
I believe the setting you want is in the bios. It has been a while since I have been in mine. It has to do with "restart after power failure"
And since your time/date are also off, I suspect you have a weak cmos battery on the board.
How old is the computer?
The battery looks like a watch battery. It is round and thin. It should be replaced.
Jun 09, 2009 | Intel D845GVSR Motherboard
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
Compaq Presario R4000 Notebook won't boot
Seem to be a problem with your power switch doing malfunction or bad motherboard connector or your computer has been setting at hibernate mode. Check those settings going to >> Start >> Control Panel >> Power Options..........Set your droplist to "never: and also UNCHECK the hibernate mode.
Another tip, take out the battery, and see what happen (only connected with AC)
Oct 13, 2008 | Compaq Presario R3000 Notebook
My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
My PC Wont Boot Up???
Dear Waqar Khurshid,
What model is your PC and you should do right now is to insert a Bootable CD and troubleshoot the sysem
Jan 04, 2008 | Mercury P4VM800M7 Motherboard
Stops booting
Did you remove the components that you upgraded, and try adding them back one by one?
Will it give you a POST screen?
Does it Beep at boot time? If it is noisy try moving it to another room.
Describe the original components and then the ones that you upgraded in detail. This will allow us to better troubleshoot the problem.
Dec 02, 2007 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Booting Problem
Could be a power supply problem but suspect its a problem with the motherboard. Unless you have a spare power supply or testing equipment I would suggest you take this to the local repair shop. For $30 they should be able to give you a good idea if the power supply is shot (cheap fix) or the motherboard (more expensive). Be aware that I also found lots of cases where a bad Emachine power supply also damaged the motherboard as well.
Oct 25, 2006 | E-Machines Celeron 2.3GHz (rb-t2385)
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
