Question about Uniden 5.8GHz Cordless Phone
Base not able to connect to handset.
Hi
i brought new uniden cordless phone 5.8 ghz dxai5688-3.
it worked initially in india. then i made it to connect to vonage voip.
it worked too. but now when i connect to my regular phone. it doesnt connect ?
plz help
  • 1 more comment
  • lanybug Jan 13, 2008
    main phone tells me it is out of range and does not work while other 2 handsets do
  • Heartbug Apr 29, 2009
    HI,
    I have a uniden DSS 7955+1, I have used up all ten multi handset memories by mistake and now both handsets wont register what do i do now how do i reset it?
  • Anonymous Mar 20, 2014
    mine only came with 3 phones not 4. base went dead. already trouble shooted electric strip.
  • 3 Answers
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Posted on Mar 23, 2008
Base charge uniden
Hi sir.
handset
follow this:
press MENU
"Initial setting"
OK
"Registration"
OK
"HS registration"
OK
on Base unit:
Press and hold
{LOCATOR} for
about 5 seconds.
Nov 14, 2013 | Panasonic KXTG4011 Cordless Phone
Will the vtech interact with already an existing Uniden 5.8 ghz power max base unit and handset plus one additional handset and charger to give me four locations or just two more single handsets with...
Hi there, Your new phones will not interact with a base station from another brand of phones. If you want to use one base station, you can buy single phones of the same model and brand and those will interact with the original base station. Your new phones will not connect to the old base station Sorry, Alex
Jun 03, 2011 | Vtech CS62192 Cordless Phone
I have three handset cordless phone only the main base phone work the other two says connecting when you turn it on but it wont connect it have loss its connection with the base phone
Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 27, 2011 | Uniden 5.8GHz Cordless Phone
I have a Uniden cordless phone #D2CT 6.0--I love the phone but the party on the other end of the line can barely hear me -how can I fix this or this a bad phone???
At 20 ft line of sight, you should have perfect reception with most any cordless phone.
The fuzzy signal can indicate:
1.
A weak signal between base and handset.
20 ft line of sight should have a good strong signal.
Your handset may be defective.
Or, your handset battery may be weak.
Your base unit may be defective.
2.
You may be experiencing RFI Interference.
Is the base unit next to any other electronic devices?
If it is next to a wireless router or some other wireless device, it may be overloaded by the nearby signal (even if on a different frequency)
I've got a 5 year old Panasonic 5.8 Ghz cordless phone connected to my VoIP box. I just tested it from about 25 ft away from the base unit in another room with a wall in between and my reception is perfect.
I did the same test with my Panasonic DECT 6.0 phones (1.9 GHz). The first handset is slightly fuzzy, but otherwise good signal. The 2nd handset was perfectly quiet with good strong signal. So, there is a difference between two identical handsets connected to the same base unit. This indicates to me that one handset is better tuned than the other. Nothing I can do about that but get a new 2nd extension cordless handset. Sometimes, it's just luck of the draw
Feb 15, 2011 | Uniden DECT 6.0 Cordless Phone ID
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
UNIDEN cordless charger for india
UNIDEN DOES NOT SUPPORT SERVICE IN INDIA, TRU 9466/TRU9485 WILL ONLY WORK IN THE US AND CANADA. USING ANOTHER CHARGER COULD DAMAGE THE BASE.
Feb 16, 2009 | Uniden 2.4GHz Handset
Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Oct 06, 2008 | Uniden Cordless Phone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
May 03, 2008 | Uniden Cordless Phone
Phone Installation - Out Of Service
Find the manual on the link below. Check batteries are charged preferably for a few hours then perform the reset as per the manual: To re-initialize the handset and base: 1 Disconnect the power to the base. 2 Remove the handset battery pack. 3 Wait at least 15 seconds. 4 Insert the handset battery pack. 5 Connect the power to the base. 6 Put the handset in the base to re-initialize. 7 Wait for handset to display READY (or handset name). http://telephones.att.com/docMgt/public/art/306/2255_.pdf
Jul 28, 2007 | AT&T 2.4 GHz 2255 Cordless Phone
Uniden 5.8GHz Cordless Phone Logo
394 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
