Question about Whirlpool GD5SHAX Side by Side Refrigerator
We have a Whirlpool GD5SHAXL side by side that has leaked alot of water overnight underneath. The leak is not coming from the copper line that comes from the wall and goes into the back of unit. We haven't changed our water filter after it warned us, is that the problem or something else? We have turned off icemaker and disconnected copper tube and left our fridge plugged in. BIG WATER MESS! BROUGHT IN THE SHOP VAC, NEED HELP WHAT TO DO NEXT?
SOURCE: Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Posted on Feb 03, 2008
aborcass
  • 2651 Answers
SOURCE: defroster leaks
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
bobicehouse
  • 1524 Answers
SOURCE: I have a new Whirlpool refrigerator (model
Order an "Icemaker" install kit with plastic tubing. This will solve your problem.
Bi Coastal Appliance Parts @ 1-800-673-1262
Posted on Mar 13, 2011
kdrake84
  • 262 Answers
I despise the copper water lines on refrigerators for exactly the reason you have mentioned. This is why my customers will not pull out the refrigerator to clean behind it and to clean the compressor area which in turn causes non cooling issues.
I have many times installed just the plastic water line seen on many part distributor websites.repairclinic.com
You now will be able to move your refrigerator in and out without the worry of crimping the line. If you can find a long enough Stainless braided line....even better.
Just ignore the Whirlpool instruction guide on the matter.
It should not be necessary to use teflon tape on compression fittings. The compression fitting is made to seal without the tape.
Using a reverse osmosis should not harm the copper line. If you have hard water this would have a tendency to harm the copper more than the osmosis filtering.
You can use a brass fitting but with the plastic line you would not need one.
Here is the link that will show you the line you can use. The copper line is not for the water but for the compressor.
Click on the link http://www.repairclinic.com/Hose-Tube-Or-Fittings-Parts?s=t-ED5FVGXWS06-%3d%3dc23
if you have any other questions and or concerns please post.
Keith
Leaking rear white valve at lower back of whirlpool fridge.
Hello is the valve leaking where the water line comes to the top of the valve?
Sep 27, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from underneath right side of refrigerator. Shut off water line to ice maker and still slowly leaking. Where is this coming from?
check the defrost drain line and catch tray under the fridge. you may just have moved the hose out of the tray or the tray may be full.
or it could just be your water valve has a slow leak. try turning off the water farther back on the supply line.
Dec 12, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice Maker has ice forming underneath where ice cubes drop. It is leaking water from somewhere?
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Nov 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a baxter mini rack electric oven and water started leaking out of the right side of the oven while cooking bagels. any ideas on what is causing this
Sounds like you have a water leak! The right side panel needs to come off. Here you will see your copper water lines. Try steaming while watching to see where the water is coming from, most likely its coming from the two spray nozzles that enter the oven near the top in the front and rear. If the leak isn't obvious have an authorized technician service the oven. A leak in this part of the oven left unattended could cause more damage and potentially a fire.
Feb 03, 2009 | Baxter OV300E Stainless Steel Electric...
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
