Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
Posted on Oct 04, 2009
Hooking a camera up to my hdtv - Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Panasonic tv will not turn on red light flashing 3 times what does it mean
I hooked a exterior camera up to comp.1 and it worked just fine for hours then the whole thing shut down and light wouldn't stop blinking 3 times so I disconect the camera unplug tv for 3 mins plug everything back up and this time put camera on video 2 and it all works fine. It was like duh did you check to see if it had gas.
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
How do I get the HD on this model? Which cables/hook up should I use? I do not have a cable box or set top box but if these are required, please let me know. Thanks!
Your unit is HDTV ready but is not an HDTV. It is capable of displaying HDTV only through the component inputs. Your tuner is analog NTSC and will not receive HDTV or digital.
You could get an HDTV picture using a Blue Ray DVD and hooking up the component connectors from the DVD to the TV.
The only other way would be to get an HDTV tuner with a component output and hook it up the same way, component out to component in, and hook the tuner input to an off air antenna (receiving HDTV) or cable or satellite with HD signals.
Thanks for using FixYa and for the great rating.
hardrocko
How to hook up digital camera to tv
if your camera has a video and audio cable then it is possible,just connect the one part to your camera and the other part to the audio and video output of your tv and the switch your tv to AV, if it does not display interchange the cable you connected to the tv.
Linking computer and HDTV
if you have a AV option in it you can get a av cable from store and connect it to ur tv
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
5helpful
2answers
How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
