Question about Hannspree Televison & Video
Can not get tv out of standby mode it is Hannspree lcd ht11 model no t191h orange power light is on but black screen and not responding to anything
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
SOURCE: Westinghouse LVM-37w1 Goes immediately into standby mode
Power suplly. In my case I should have done research on a lot of things before purchase - westinghouse doe snot acknowled any power supplly uissue but they would say that, and this is a direct quote from them, "Westinghouse's failure rate is less than 2%, which is great by industry standards. Unfortunately, when you sell millions of televisions, 2% is still a lot of televisions. There have been no recalls on this model (or any of our models), but it's not surprising to find a similiar issue on more than one of millions of televisions."
In other words they calim there is nothing that is really their fault. However the first thing the repair guy said before he even looked at it was "Power supply". He opened it up and tested - power suplly. However to complicate matters more I made is huge mistake of buying into a scam offered by eCost via Service.net . A two year, 100%, in home service, warranty. Bottom line is since June 8 my Monitors has not worked and sine July 7 it has been sitting untouched, not here, but at a rprair facily over 50 miles away. As of yesterday August 7, I was told Westinghouse no longer makes or provides power supplies for this unit. On top of that the repair facility will not return it to me unless i pick it up why? Because it can't be fixed and because service.net will not pay them to return it to me.
So solution at thi point for anyone with power supply issues is to try and repiar it yourself. And then in the future never purchase anything from westinghouse again. (And if offered any sort of 100% all cost covere din home warrabnty from service.net run away screaming)
Posted on Aug 08, 2008
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
SOURCE: My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Posted on Jan 08, 2009
SOURCE: Orange Led syndrom
Hey got it fixed-problem is that power supply unit (PSU) is dead- cost me approx 100 EUR- good thing is that fits most classical philips lcd tv PSU- should be found at any TV repair shop
Posted on Mar 19, 2009
NEC LCD 4610 Screen black.
Possibly the replacement power supply may have failed.
Feb 02, 2014 | NEC Televison & Video
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
My plasma's power light is orange and when I press the on/off button nothing happens. What should I try next?
Hello Sir, hi, when your TV's power light is orange, it's on "standby mode" meaning the power supply will not respond to any power switch press. the standby by mode can be anything, this could be that the TV is not receiving any signal, this could also be that some thing a part or a section of the TV goes bad that makes overload. This needs to be checked thoroughly, I cannot be particular on this section simply the trouble is to broad to explain, this needs a pro for checking, but if you want a quick answer, simply replacing the entire power supply board will restore the TV back.
Nov 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
The monitor is coming on, saying there is no signal being recieved when the cable linking the monitor and screen is in fine working condition, and then turns itself into standby mode. Can this be fixed?
yes it can, the lcd is not communicating with the cpu. check the cpu with a known working screen. check the data cable also, if all not changing anything check the lcd pc board, if not sure about this take it in for repairs. Be careful when handling power circuits!
Oct 28, 2010 | Hannspree HW191D LCD Monitor
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
The yellow light on the front of the tv fades in and out constantly while the tv is off.
When the TV is off but still connected to the power the light is usually yellow/orange/amber signifying that TV is in standby mode. If you do not want to see the yellow light, all you have to do is unplug the power cord. But by doing that you may have to reconfigure the TV.
Jan 15, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Polaroid tv w/ black screen
hi..then there is a problem in your smps
power supply.If you have the warrenty period
take it immediately.
check it out..
thank u..
rate me..
Feb 28, 2009 | Polaroid FLM-3732 Television
Need assistance on hannspree 32p
I've had exactly the same problem and it seems to be happening across a whole range of 2 year old LCD TVs World wide. Replacing the Inverter seems to be the only solution (sometimes but not 100% effective). I'm trying to track down if you can get an Inverter for a Hannspree at all and if it's going to be cost effective
Dec 13, 2008 | Hannspree XV32 32 in. LCD Television
Televison & Video Logo
269 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
