Question about Garmin zumo 550 GPS Receiver
No power As for the other faults reported, my Garmin 550 worked fine for about 2 months; it was turned off and left in the glove compartment of my car overnight. Next morning it wouldnt start and still wont start even when connected to either the car or bike mount or when plugged into USB charger. I have tried to remove the battery to no effect and a hard reset but again no effect.
  • 2 more comments
  • joedredd Jan 03, 2008
    no power and i dont know how to get the battery out
  • let her ride Feb 15, 2008
    Having the same problem. Had the zumo for only two month and this is the second time it won't power on. The first time I plugged it into the house electicy and after a while it came on. This second time it won't come on at all not matter what I do.
  • Anonymous Apr 13, 2008
    never had a problemtill now. plugged ina usb conneciton by accident.
    Now it doesn't go off or on.
    Absolutely no response. Howver, there is a little picture onthe screen that shows a computer and cord.
  • syssh Apr 17, 2008
    Having the same problem. Had the zumo for only 9 month and it won't power on. purchased a new battery and charged it up still no power up. Any one have any ideas?
I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
Posted on Jan 04, 2008
Joeredd, remove the allen hed in the back... in the center that removes battery
Posted on Feb 12, 2008
Posted on Apr 17, 2008
The sound on my garmin zumo 550 is not working right it has been working fine. But this morning when I hooked it to my Harley ultra classic it was reel low upon further check it was only coming through...
sounds like the Audio patch cord, i had around 5 of them that do that ...sometimes i hear the music thru one speaker, cracking noise sometimes it works when the wire is twisted, but i would try a new patch cord first.....my patch cord worked fine on some stereo units others break up
Nov 07, 2010 | Garmin zumo 550 GPS Receiver
Recharging/Traffic Problem with Garmin StreetPilot 550
Initially, you would need a DVM (voltmeter) to check if there is an output from the cigarette lighter adapter/charger. Your post "...green lights on cable is on (the one closest to the socket)..." indicates that there is 12VDC coming in (from your car) but "...the other one is not..." signifies that the adapter is not processing the incoming 12VDC and forward it to your Garmin StreetPilot 550. With the DVM, you can measure the output B+ (which should be something like +5VDC) which is also the output voltage of your computer's USB port.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 26, 2008 | Garmin StreetPilot c550 GPS Receiver
The battery will not charge and the dash instrument cluster will not work. we have checked all the fuses and none of them are blown. its a 2005 ford f550
It sounds like you have a fuseable link that has melted... Check down by the starter... There may be another connector and main power terminal in the left side of the engine compartment but remember when you look inside the engine compartment it will be on your right....
Oct 08, 2009 | 2005 Ford F 350 Super Duty
Garmin gps keyboard -- left upper corner fails to work when press ''A'' is C and others on left side are incorrect also. How do I fix?
Sounds like you need to recalibrate the screen. This can be done by following the steps below:
To Calibrate the Touch Screen on a zūmo®:
1. Turn the unit Off and make sure it is not attached to any outside power source.
2. Power the unit On, continue to hold the Power button for 1 minute. 3. A screen will display that says, Press dot in the lower left corner. 4. Release the Power button and touch the sequence of dots until your unit says Calibration complete.
Sep 19, 2009 | Garmin zumo 550 GPS Receiver
GARMIN WILL NOT TURN OFF
I have the same problem. Seems to happen when I get a photobox warning in a tunnel an after that loose satelite connection in the tunnel. This has happened two times at the same place, The only solution I`ve found so far is to take out the battery and start again. Hopfully there will come a software update for this soon!
Feb 22, 2009 | Garmin zumo 550 GPS Receiver
Garmin gps
Keeping the unit in the glove compartment is not a good idea, for a couple of reasons. If anyone suspects you have the unit, the glove box is the first place they will look. Secondly, it gets very hot/cold in the glove compartment, depending on the ambient temperature. It is not good for the unit, or the battery, to be subjected to extremes in temperatures. It is possible the battery is no longer working properly as a result.
Jul 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Touch screen not working properly
I'm not familiar with the Zumo family of GPS from Garmin, but if they are similar enough to the StreetPilot, you should be able to recalibrate the screen. In the StreetPilot series, to recalibrate you turn the unit off. Press and hold the bottom right of the screen and turn the unit on. Keep pressing the screen until the calibration information begins. Try this, see if it works on the Zumos, too.
Mar 11, 2008 | Garmin zumo 550 GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
529 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
