Question about Electrolux EW1200i Front Load Washer / Dryer
Er20 comes up on my washer
Hi, i have a electrolux eco valve front loader washer, model number EWF1080, it is just over 2 years old. all electrical. once it has been on for approx 15 - 20 mins it stops and beeps with a message ER20. i can skip the stages of the cycle but have to let the water out thru the emergency thingo at the bottom of the washer, i can also spin cycle if this is left open to let water out. is this the pump or a blockage in my hose?? or something else?
  • 139 Answers
Your on the right track .... To narrow it down all you have to do is disconect your waste pipe from under the sink or where ever it goes to and lower it ground level , if the water startss to flow out by means of gravity then you have no blockage and its the pump if water does not flow out then its a blockage....
Either to clear the blokage or change the pump turn the machine upside down as both are easily accessible from there hope this helps... any questions dont hesitate to ask...
Posted on Jan 22, 2008
I have Electrolux front load wahser Model EIFLW55HIW0 that is about 6 years old, Has worked without a problem for many years. recently started giving E35 error codes. the water doesn't ap
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
Sep 28, 2014 | Electrolux Washing Machines
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
Nov 05, 2011 | Electrolux EW1000i Front Load Washer
Bought "Electrolux eco turbo lava
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 27, 2011 | Washing Machines
Drum wobbles front and back so on spin it goes out of control and shakes up and down electolux eco valve 6.5 kg front loader
Washing machines usualy have springs on the front and back which can sometimes snap or come loose. you can usualy see these by looking at it from beneath.
Also they have a ballast which is usualy a small piece of concrete attached to the bottom of the drum. This is to stop it from bouncing around as well. these also have a tendancy to either snap their fixings (Bolts) or split and fall off.
In either sutuation it should be fairly easy to repair. I have had both of these situations on a BEKO. got the parts from the NET.
Hope this helps.
Jun 06, 2009 | Electrolux EW1000i Front Load Washer
How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 04, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Electrolux front end loader
How Old is the machine: Is it within the 5 year major parts cover? If so the drum bearings are covered.
Aug 26, 2007 | Electrolux EW1000i Front Load Washer
Electrolux EW1200i Front Load Washer / Dryer Logo
420 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
