Question about Dell Latitude C640 PIV 2Ghz, 20-40Gb, 256-512Mb, CD, FD ,Sealed,Refurbished,No OS. (DELLLATITUDEC6402) PC Notebook
Dell latitude c640 will not start up, says "No boot device available", what do I do?
  • 154 Answers
When we talk about laptop won't boot up it is a hardware failure.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
Good luck and take time to do a hard troubleshooting this trouble is not easy as well. You need to be care full in removing the some parts so that the other will not affected and being damaged.
Posted on Oct 04, 2009
2 Suggested Answers
  • 148 Answers
SOURCE: hi guy plz help me i got a dell latitude C640 and
hi,
check if any updates are availble for the bios
go to support.dell.com > drivers and downloads > put in your service tag and check if any update is available you can update your bios
you can also try restore your bios to factory settings you have an option for this in the bios menu as well and then connect the drive and then boot.
Further Queries are welcome
if you think my solution was helpfull please do rate me
Posted on Mar 28, 2009
C640 can't boot up
Ok.Better reinstall the os.Because disk boot error cannot be solved is suppose...To install the os follow these steps.
Step 1:Power on your system and press DEL key
You will see a blue screen with some options on it in white. (you can only use your keyboard to navigate in this screen). Go to the Advanced Setup Options ---> then select Boot Priority ---> 1st Boot device to be Floppy drive , 2nd Boot device to be CD-Rom drive
Step 2:Insert the Bootable DOS floppy in your Floppy Drive. Press F10 to save the bios settings and exit. (Your system will re-start automatically)
Step 3: Let the Dos load from the floppy and A: shows up.
Step 4: Change the Command prompt to HDD Drive letter, it will be D: or E in which u have Xp cd contenet.And type If xp content in d:under x folder mean.D:cd\x and press enter.
Step 5: now type on the D:\ prompt -- setup.exe and press enter
Step 6: follow the prompts there after. and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Dell Latitude C640 Notebook
Have laptop that has black screen and says no boot device available every time i turn on computer. what can i do?
Boot to system system BIOS, reset defaults, save settings and reboot, see if the error goes away. If so, then the reserve battery on the mothebroard is bad. If no change, then reseat the Hard Drive, and try again. If still no change, a HDD replacement is likely
Jun 05, 2009 | Dell Latitude C640 Notebook
Hi guy plz help me i got a dell latitude C640 and its not willing to detect my cd drive. after loading bios its telling me the device in the modular bay cannot be recognised and its not booting into...
hi,
Mar 28, 2009 | Dell Latitude C640 Notebook
Ndevice available
Press F2 go into the BIOS, check the hard disk settings, make sure it is set to auto (detect)
Nov 08, 2008 | Dell Latitude C640 Notebook
BIOS!!!
No boot device available means that there is no Operating System available. F12 is the key that will get you into the Dell BIOS, not F2. Once there change your Boot Order to your HDD first. Good luck!!
Sep 25, 2008 | Dell Latitude C640 Notebook
Dell laptop memory install
available physical memmory is what all your programs on your comp is using like windows virus software drivers im thinking you probably have spyware or bugs in your comp that could be bringing memmory down
total physical memmory is what you just put in
May 09, 2008 | Dell Latitude C640 P4 Mobile Notebook
Dell latitude c640. comes up with error immediately after ram check displays... "primary hard disk drive 0 not found no boot device available - no bootable devices--strike F1 to retry boot, F2...
Seems to be a problem while detecting the hard disk. Please contact customer service if the laptop is in warranty.
Let me know what happens.
Apr 30, 2008 | Computers & Internet
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell c640 audio problems
i installed windows xp service pack 3 in dell c640 latitude laptop after which the multimedia audio controller driver is not installed.
Apr 23, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
259 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
