Question about Apex Digital GB43HD09 43" Rear Projection HDTV-Ready Television
Set started to smoke and created strong burning odor then went out. Please Advise
Why suddenly a strong odor of burning fuel when heater is operating?
Improper air to fuel mixture, way to rich.
Does this heater have the ability to adjust ratio?
if so, play with adjustment until odor goes away.
Mar 25, 2015 | DynaGloDelux Dyna Glo Delux Liquid Propane...
I have a 2100 Electrolux cannister vac. I have just noticed an odd odor (similar to burning) and the protection mode light went on. Can you advise of steps to take to rtrouble shoot and what might be...
The motor is probably burning out, or has. Smell the exhaust port. If the odor is especially strong, here, then that's the problem. You'll need to take the vacuum to the nearest Aerus Electrolux store for definite diagnosis and repair/replacement of parts.
http://www.aerushome.com/storelocator/index.cfm
Feb 01, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Shaking upon starting of car and while driving. Strong gas odor.
Looks like a Vacuum problem and gas not burning. Does your car smoke ?
Dec 12, 2010 | 2003 Nissan Altima
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Bad odor, burning eyes from fumes.
It sounds as though some Plastic part is being heated up to Fuming Point, being melted, and releasing toxic gas, I would advise not using it until you can get it looked at by a professional.
Feb 20, 2010 | Procom ML300HGA Heater
X type jaguar starts but no accelerator and loads of black smoke
Burning Oil!!! If its not burning carbon deposits and choking on an intake blockage. Both will cause severe power loss, though intake blockage is not an immediate sign of fatal engine problems. Power loss due to oil burning is a symptom of warn out piston rings and cylinder walls. This allows oil to seep up into the combustion chamber which at the same time allows the needed fuel/air compression to escape between the piston rings and cylinder walls. Either way, this is NOT a good symptom to experience. You may confirm or rule out the worn out internal engine components by checking the oil dip-stick for fresh gasoline odor......I would strongly advise you take your car to a reputable mechanic or dealership. And I'm really sorry, but as much as I love Jaguars, parts are EXPENSIVE! Your monetary health might suffer less had you even owned a Ferrari
May 11, 2009 | 2005 Jaguar X-Type
New appliance bought in a store in Ottawa (Linen'n Things Orleans) which is going under and will not take back purchases. My new Delhonghi Counter Top Convection Toaster Oven is emitting a very strong...
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Dec 02, 2008 | Microwave Ovens
Odor of burned popcorn!!
The smoke has permeated the works, so a more aggressive cleaning will be needed.
There are many good suggestions for cleaning and deodorizing microwaves here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Apex Digital GB43HD09 43" Rear Projection HDTV-Ready Television Logo
12 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
