Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The washer filled up with water and stopped, I tried plugging the washer in different outlet it starting humming and nothing else. Now the washer is leaking.
  • 121 Answers
You have something in your pump and is stopping the motor from running. you will need to remove the cabinet to repair this unit.
Posted on Oct 16, 2009
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Kenmore Elite Washer Stopped mid-cycle. Only hums when turning on
You will have to drain it, those units use a belt to drive the transmission. It may have come off the pulleys or broken in half. If you can get a large wet and dry vacuum, that would make it easier to drain. Hook the vacuum to the drain hose and remove the water.
Mar 13, 2017 | Washing Machines
I was going to wash a load of towels and the washer filled up but I realized it wasn't enough water in it so before I could set the dial for more water, it stopped filling up so I set the dial for more...
Look around at outlets that are close by and make sure you didn't trip one of your GFCI breakers or plug in something to the same outlet and make sure you have power at the outlet where the washer is plugged into.
May 30, 2017 | Maytag Legacy Series Top Load Washer
But will start with hot.kenmore 70 wont start with the cold water
Hi, First thing you want to do is start the cold sysle and listen for a faint hum. If there is a hum,turn supply valve off and remove fill hose.
Look inside the valve on the washer and see if something is plugging the screen. If the screen is plugged flush it out (do not remove the screen.
If the screen is not plugged, and there was no hum when washer was trying to fill with cold water, you will need to change the inlet mixer valve.
Please let me know if this has helped or if I can assisst you further.
Thanks
Vic
May 27, 2009 | Kenmore 22422 Top Load Washer
Maytag atlantis Top loading washer
it sounds like a bad lid switch.
Apr 07, 2009 | Maytag Washing Machines
Water will not stop filling keeps filling
Hello, you can have a couple of different problems. How about we start here.
1st I want you to turn the water on then unplug the washer from the outlet. If the water continues to fill with no power to it then you have a bad water valve.
Try this then get back to me
Jan 04, 2009 | Washing Machines
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
149 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
