Question about Garden
How do i attatch collectoin bag to ryobi pbv -30 and **** leaves not blow thanks
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: A manual for a Ryobi
You can get the manual on the link below. english starts on page 9 to 17.
http://ryobi-service.net/filestore/1099/PBV-30A_25%20lgs.pdf
Good Luck and please accept the answer
Posted on Sep 06, 2010
  • 2239 Answers
SOURCE: I have a Ryobi PBV-30A
If you clean the dirt off the carb, the series no. and model no. will be etched into the body of the carb by the fuel inlet nozzel.
Posted on Feb 09, 2011
Testimonial: "Thanks, quick response, problem solved !"
I have a Ryobi PBV-30A Blower and require a diaphragm kit. It is fitted with a Walbro carb, however, I cannot tell which model of carb. Can you tell me the Walbro model number/type? Thanks Marc
Feb 09, 2011 | Ryobi Garden
I have a Ryobi blower/vac mulcher-RBV18.The bag is broken need a new one where to get one i live in Dandenong Victoria Australia.
In Australia Bunnings are the dealer for Ryobi products.
I have the same one and also need a bag for mine.
You have to order the bag from the "special orders" section as it is a discontinued item at Bunnings.
Unfortunately they told me yesterday (15/1/11) that Ryobi have no stock and it will be May before they arrive from Japan.
The Ryobi part number is 4072241 and Bunnings quoted me $15.20.
Hope that helps.
I'm going to take mine in with me to Bunnings today to see if I can modify a bag from another model to fit. Maybe if you don't want to wait until May you could also try that?
Good luck,
Eric Oppel
Jan 04, 2011 | Ryobi Garden
Ryobi pbv-30a will not start this blower was used about six times but is now out of warranty has a strong spark but will make no effort to start
Hi, Make sure your fuel /oil mix is correct, then, take a capfull of fuel and pour a few drops down the cylinder. After replacing the plug, give the starter a try. With fuel in the chamber and a confirmed spark, the engine has no choice but to fire. From here, you can determine if the idle adjustment needs to be changed. Hope this helps.
Dec 04, 2010 | Ryobi Garden
Hi,My Ryobi 30 Petrol with Brush Cutter attachment has so much vibration I cant use it..
This is likely a mechanical problem caused by either 1. A serious imbalance with the cutter attatched to it 2. The engine is failing and the main crankshaft bearings are worn causing crankshaft "wobble" setting up the heavy vibration you speak of.
Aug 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Don't know how to attach the vacume
The discharge tube and collector bag will replace the blower nozel ( where the air comes out when blowing). The large diameter tube ( pick up tube) will attatch to the impeller side. There is a plastic gaurd on a spring loaded hinge. Open the gaurd and attatch the large tube.
Nov 28, 2009 | Poulan & Vacuum Kit Attachment
It vacums but will not blow
If it vacuums, it is working. The blower tube goes where the bag attaches. Basically, the machine sucks from one end and blows out the other. You just use the end based on your job. Rather than **** leaves in, it pulls in air and where the bag attaches, that's where the high speed air blows out. Hope this helps.
Oct 25, 2009 | Ryobi Garden
Ryobi PBV-30A Carb problem
I have a rayobi PBV30A petrol trimmer and it keeps dying once you increase the throttle speed runs on idle.
Feb 17, 2009 | Ryobi Garden
Kirby Ultimate G Series
Ok, I will try to explain this as well as I can. Please bear with me. Remove the dust bag, cover and all, from the machine. Attatch the shampoo tank to the part where the dust bag attatched on the machine (not on the handle). Remove all attatchments from the front of the machine, and attatch the shampoo foam "collector", ensuring that the belt is over the drive. Connect the small hose between the tank and the foam collector. Mix the water and shampoo as directed on the bottle, in the tank. Turn the knob on the top of the tank to on, then start the machine. I run the foam over about three sections, and then turn the knob back to off, lower the collector, and run back over it to pick up all the foam and dirt. I hope some of that makes sense.
Apr 12, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
