Question about RCA HD52W59 HDTV Projection Television
I have a RCA HDTV and it is continuously changing from CMP1 to FRNT and it keeps going. It also turns itseklf on after we turn the tv off.
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
http://servicemanuals.vstore.ca/
Posted on Jun 08, 2008
tlm931
  • 273 Answers
SOURCE: RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Posted on Nov 11, 2009
Slinteriors
  • 8617 Answers
SOURCE: my 52" RCA HDTV Flat Screen TV
replace the deflection board. Your model uses the ITC222A deflection PSB-260 You can get the replacement deflection board from www.tvrepairworld.com
Posted on Apr 13, 2010
Slinteriors
  • 8617 Answers
SOURCE: RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Posted on Jun 29, 2010
Just got it out of box,wedding gift,a year ago.no owner manual.no sound.hooked up to cable,it keep saying...unusable signal.At the bottom it says CMP1..
You may need to change the settings in your channel settings menu from "Antenna: Air" to Antenna: Cable" if you have a coax cable hooked into the back.
Jun 06, 2011 | RCA L32WD250 32 in. LCD HDTV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an extended amount of time. The green lite comes on ,stays on a few seconds and goes out. After continueing...
well usually what works for me is a small heater on near the tv or just keeping the room above 65 degrees. There is a way on some tv's to turn off the power saver and that will keep your tv warm. But on others you cant turn it off so you have to deal with the heater or keeping the room warm cause that tv wont turn on for anything exept if its warm....
Dec 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
Rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Nov 08, 2008 | RCA 27V530T 27" TV
RCA 42in Projection
There is a short, the tv is trying to come on but the fault is keeping it from coming on. Try to find a bad board inside the tv, check all fuses or continuity. Thatll give you a place to start from.
Aug 26, 2008 | RCA Scenium D40W20 40" Rear Projection...
High pitch shrill when input device not DVI
use of silicon or superglue on a coil next to the flyback that solved the problem in a similar model RPTV. Easy fixes first
Jan 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
Hdtv function only out of focus
Most have HDTV Converter Box with component, Going to RGB Cmp1 or 2 a composite output cable box will not work.
Oct 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
12 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
