Question about Garden
Engine shuts down when it gets hot.I have replaced the coil,tuned up with pionts and plugs.Also removed intake and resealed it.I'm wondering now if it has something to do with the govenor.It seems to just shut off the intake and choke it down.
  • mickey813
    mickey813 May 11, 2010
    what moter do you have
    Sergeant:
    Champion:
  • 257 Answers
I am not a expert just trying to help,it sounds like it is vapor locking,, check your gas lines to see if they are getting hot,,and check to see if carb. is getting hot maybe be a exhaust leak causing gas to bubble hope this help
Posted on Oct 04, 2009
Tip
Replacing spark plugs and coils on Mazda Tribute V6
Here are DIY step by step instructions for replacing the spark plugs and / or coils in a Mazda Tribute V6 (based on a 2001 Tribute).
This is a lengthy procedure, but don't be frightened, it works...I have done it a few times. This will save you a few hundred $$$ if you do it yourself. Make sure to read all of these instructions, preferably while looking at your engine, before you get started. You will need 2-3 hours to do this job.
NOTE 1: IF YOU HAVE A SPECIFIC ISSUE WITH CYLINDERS/COILS 4, 5, OR 6, YOU ARE IN LUCK, YOU ONLY HAVE TO REMOVE A PLASTIC ENGINE COVER. IF YOUR ISSUE IS WITH CYLINDERS/COILS 1, 2 OR 3, OR YOU ARE CHANGING ALL OF THE SPARK PLUGS, YOU WILL HAVE TO REMOVE THE INTAKE MANIFOLD. THESE INSTRUCTIONS COVER CHANGING ALL OF THE SPARK PLUGS AND CAN BE USED TO REPLACE ANY OF THE COILS.
NOTE 2: IF YOU ARE THINKING OF REPLACING YOUR SPARKPLUGS BECAUSE YOUR ENGINE IS RUNNING ROUGH, PLEASE DO YOURSELF A FAVOR AND GET THE ENGINE SCANNED FIRST TO MAKE SURE THAT A COIL IS NOT THE ISSUE. YOU CAN REPLACE YOUR PLUGS AND BAD COILS AT THE SAME TIME WITH THIS PROCEDURE. YOU WILL BE UPSET IF YOU DO THIS WORK TO REPLACE ONLY YOUR SPARKPLUGS, THEN YOU FIND OUT AFTERWARDS THAT A COIL WAS BAD AND YOU HAVE TO DO IT AGAIN LIKE I DID.
1. Tools: Pliers, ratchet wrench, ratchet wrench socket extension, 8 mm socket, 10 mm socket, Spark plug socket, flat head screw driver, plastic zip tie, plastic cup or bowl. Not necessary, but very helpful: Magnet on an antenna to pick up dropped nuts/bolts.
2. All directions are given from a point of reference as if standing in front of the car, except for removing the coils and plugs from firewall (back) side of the engine.
3. Using flat head screwdriver, loosen band clamp on large rubber air intake hose where it connects to the intake manifold on the right side of the engine. Slowly work rubber intake hose off of intake manifold.
4. Unplug wires from back side of air idler valve - small unpainted metal part mounted on top of air intake on manifold (close to where the air intake hose connects to intake manifold).
5. Disconnect small rubber hose from top of the ERG valve (black metal disk near back right side of manifold.
6. Remove the two bolts that hold ERG valve to manifold bracket. Use the 10 mm socket and ratchet to remove these. If you are trying to remove the 8 mm bolts, you are removing the wrong bracket. Be careful, there is a gasket between the manifold and the ERG valve, make sure it does not fall out when removing bolts. Place bolts and gasket in cup.
7. There is a small plastic sensor just to the left of the ERG valve towards the back of the engine. If you look at how the sensor is attached to the manifold, you will see that the back left side bolt that holds this sensor, also connects the intake manifold to a plastic wiring harness at the firewall. You will need to remove the 8 mm nut from this bolt to free up the intake manifold in a later step. Now remove 8 mm bolt from other side of sensor. Might need the socket extension to remove these. Place nut and bolt in cup.
8. Unplug wires from the back of the sensor discussed in the previous step (7).
9. There are 3 hoses of different sizes plugged into the back of the manifold. Unplug all three hoses from manifold. Remove zip ties if needed to slide hoses off. Left hose may have a compression clamp, use pliers to loosen clamp while sliding hose off.
10 There are two large black plastic wiring connectors supported by the back left side of the manifold. They are supported by plastic clips with plastic barbs. Use the flat head screw driver to pry off the support clips from the manifold - don't worry, you won't break them. You will be able to plug them back in later.
11. There are still a few things attached to the intake manifold, but there will be enough flexibility now to lift up the manifold and replace the spark plugs.
12. Remove the plastic engine cover - there are three 8 mm nuts to remove. You will need the socket extension. One the nuts are removed, you will have to wiggle the cover off especially on right side. Place nuts in cup.
13. The plastic intake manifold on top of the engine is now exposed. If you look down at the front side of the engine, you will see the coils for cylinders 4, 5 and 6 (going from left to right). The tops of the coils will probably say "Motorcraft" on them. Also, there are two cables attached to the top of the manifold - leave them alone.
14. There are 8 bolts that hold the intake manifold down. The bolts are located in two rows of 4 across the top of the manifold. Loosen them all using the 8 mm socket with extension. Note: these bolts do not come completely out when fully loosened.
15. Slowly work the intake manifold loose by lifting up on each side. NOTE: Work the manifold off of the bolt discussed in step 7 (back right side of manifold), NOTE: Work slowly watching for anything that might be hanging up. You should eventually be able to get about 4" of clearance between the back right side of the manifold and engine, and 8-10" of clearance on the back left side. Move around to the passenger side to help lift off the manifold. While working on the back side plugs, you will stand on the passenger side of the car.
16. Once you are able to lift up the manifold, get a cup, block of wood, anything suitable approx. 5" tall to prop up the manifold (place under center of manifold). This will keep the manifold off your hands while you are working.
17. The three coils on the back side of the engine are now visible if you are standing on the passenger side of the car (cylinders 1, 2 and 3) Cylinder 1 is closest to you - passenger side, cylinder 3 is furthest from you - driver side.
18. Each coil has one 8 mm bolt holding it down. Take the 8 mm socket and ratchet and remove the bolts from the 3 coils on the back side of the engine. Place bolts in cup.
19. Lift each coil away from engine (do not pull on wires plugged into the coil). Pull each coil's silicon rubber tube out of spark plug hole, bend tube to get it out without pulling on the coil wiring. Leave coils plugged in and lay them to the side. NOTE: If you are looking to replace a coil (or coils) simply unplug the coil wires from the old coil, and plug into new coil at this stage.
20. Using sparkplug socket and socket extension, remove each of the back 3 spark plugs.
21. Install the new spark plugs (gap them first if they are gap type).
22. Slide each coil rubber tube back into sparkplug hole and bolt down coil (8 mm bolt). Congratulations! The hard part is over with!
23. Make sure the rectangular intake port gaskets are clean on the engine (before lowering the intake manifold back down).
24. Slowly work the intake manifold back down to the top of the engine - make sure that the manifold is back on the bold discussed in step 7, and that nothing is binding.
25. Bolt the manifold back down (eight bolts, 8 mm, still attached to the manifold). Use 8 mm socket with extension. Gradually tighten the bolts going from bolt to bolt until they are all tight (don't fully tighten one bolt first).
26. Remove coils and spark plugs on front side of engine. Replace spark plugs and re-install coils. Same procedure as back side of engine, but much easier. Replace coil(s) if desired.
27. Re-install the two plastic wiring connector support clips to the left side of the manifold - push barbed clips into manifold.
28. Reconnect 3 hoses to back side of manifold. Place new plastic zip tie on hose that had zip tie.
29. Reinstall plastic sensor on back right side of manifold (8 mm nut and 8 mm bolt).
30. Plug in wires back into back side of plastic sensor.
31. Reinstall 10 mm bolts and gasket on ERG valve and tighten to manifold.
32. Reconnect small rubber hose to top of ERG valve.
33. Reconnect large air intake hose to intake manifold and tighten hose clamp using flathead screwdriver.
34. Plug wires back into back of idle air control valve (this was uplugged in step 4).
35. Leave the plastic engine cover off for now. Check all around the manifold and make sure everything is reconnected.
36. Start engine - should start and run normally (or better). If not, go to trouble shooting at the end.
37. Reinstall plastic engine cover (three 8 mm nuts). Make sure engine is not running when reinstalling plastic cover.
TROUBLE SHOOTING: If engine light comes on (and wasn't on before changing plugs), or if engine runs rough, stop engine and double check that all wires and hoses are plugged back in. If you find wires or hose left disconnected, reconnect them. Disconnect car battery for a few minutes then reconnect (to clear out engine alarm). Restart car, engine should run well, engine light should be cleared.
on May 01, 2010 | Mazda Tribute Cars & Trucks
How to change coils on 2003 expedition
please tell me in this tune up you had new spark plugs put in? if check engine light is on there are some stored codes those will give you the suspect cylinder(s) check to see if you have plug wires if not there will be a coil for each cyl. pass. side of motor starting in the front working to the back or firewall cyls are 1,2,3,4 driver side same front to back 5,6,7,8 codes will be PO301 cyl 1. PO302 cyl 2. etc. get the code find the correct cyl. unplug little connector u will need a 7mm socket to remove the bolt holding the coil in place then pull up on the coil and boot.... if u have plug wires get the code find correct cyl and follow plug wire to coil pack in front of engine there will be two one on each side in front of engine...
Apr 17, 2013 | 2003 Ford Expedition
Gets hot shouts off
could be coil getting hot and shutting down, or fuel pump getting hot and doing the same
Aug 19, 2012 | 2000 Oldsmobile Bravada
How to tuneup 2005 chysler 300
what engine do u have? if it is a 3.5 then u must remove the upper intake manifold, the plugs are under that, each plug has its own coil, remove the coils and then the spark plugs are under the coils in a deep wells.Plugs are theonly thing changed on a tune unless u have a dirty air filter for the engine.
Sep 30, 2010 | 2005 Chrysler 300
Runs for 20 minutes, gets hot and shuts down. Still has spark
I had the same problem, took to a benz dealer, it was the fuel pump relay, cost for repair $200.
Jun 25, 2009 | 1989 Mercedes-Benz 300-Class
Mazda Protege 2001.. when i start the engine. it makes a single popping burst. and when i speed up, the noise continues and fades down after a while.. can anyone suggest the problem please..
sounds like a misfire. first check it intake hose from the air filter box to the throttle body. check it for cracks. remove it if you have to. air entering the intake behind the MAF sensor causes improper air/fuel mixture which could cause your misfire.
if all is well it could be in need of a tune up plugs/wires (don't use aftermarket wires get mazda ones) coils could also be weak.
start from plugs to wires to coils, after checking the intake hose.
Jun 22, 2009 | 2001 Mazda Protege
O2 Senser maybe...When I first start it up idles high then low
The O2 sensor input is ignored by the system computer (ECM) until the engine is hot, around 160 deg F, what u might have may be fixed by the following procedure, one other note your 1st tune is due at 100,000 miles, have you reached that? if so replace plugs and check plug wires for damage. Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation, it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Mar 24, 2009 | 1995 Oldsmobile Cutlass Supreme
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
303 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
