Question about Kenwood KR-V5580
I can't turn up the volume more than 50%. when i do this, the reciever goes standby. 2 speaker : 8ohm
  • 458 Answers
SPEAKER BAD OR CHECK SPEAKER WIRE OR REPLACED WIRE
Posted on Oct 04, 2009
Hey i have reciver vsx-520 sk and when i turn on it goes off after 2 seconds also i made reset to the factory defaultsThe problem was when i did listen to music on 49 volume was ok but when i turn on 50...
First of all check the impedance of the speakers are they below 4 Ohms or are you using speaker A and B together.
If the standby light is blinking it means you have an output short circuit, i.e you have blown one of the amplifier channels in your Receiver. Did it run hot or have you kept a DVD/CD player on top of the receiver ( one of the most common reasons for failure is blockage of ventilation on top of the receiver ).
To fix it you will need professional help as its quite complicated to fix a multi channel receiver .
Jun 03, 2011 | Pioneer Audio Players & Recorders
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
My reciever is shutting down completley when i try to turn on the second zone. i tried rewiring it but it still does it could it be the reciever or do i just have the settings incorrect?
if the reciever shut down with zone 2 on, zone 2 volume at -3 and nothing connected to zone 2 it needs repair if not reconnect the speakers to zone 2 speaker connections and make sure you do not have more than 4 pair of speakers with impedence matching volume controls or a impedence matching speaker selector box
Jun 15, 2009 | Denon AVR-785 Receiver
I have a Bose Accumass 6 system connected to an Onkyo amp running as a entertainment system on our boat. The quality is sufficient for what we need. The amp (a TX-DX575) has A&B speaker switches for a...
two 8 ohm speakers in parallel is 4 ohms.
if series 16 ohms.a high resistance will just produce less power.
too low a number can activate the speaker protect,or blow the amp.
radio shack sell wall mounted speaker controls,but 5 watt max.
the best thing is to run 2 amplifiers.one for in ,2 for out
speaker a and b on the amp parallel the speakers.
if you run 2 sets of 4ohm speakers,the amplifier load will be 2 ohms,and overheat the amp.4 8 ohm speakers,gives a 4 ohm load
May 09, 2009 | Onkyo TX-DS575 Receiver
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
AVR 110 Harmon Kaedon
Looking in the manual (link below) I see that this receiver uses 8ohm speakers, check that your speakers are 8 ohms or more. I think that connecting 2 sets of speakers to the same output is the problem as when you connect speakers in parallel (i.e. just twisting both pairs of wires together) you effectively half the impedance. So if 2 sets of speakers of 8ohms are connected this way the result will be 4ohms which is too low and will cause the unit to go into standby. Try removing the additional front speakers & see if the fault persists. If it does then it is likely a fault in the wiring. http://www.harmankardon.com/product_support/support_detail.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=AVR%20110&sjump=om&#active
Jul 28, 2007 | Harman Kardon AVR 110 Receiver
Kenwood KR-V5580 Logo
123 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
