Error no 14 in model no IR 600
I have Cannon Model No IR 600 and I found trouble in the same that Befor Innitiol Rotation start It make Error no 14. What May be cous efor the Error No. 14
  • 1,294 Answers
This error caused an the fixing motor M19 is faulty or the DC controller board is faulty.For reset press COPIER-FUNCTION-CLEAR-ERR.
Posted on Oct 04, 2009
Canon ir 6570 error code 14
Hi. This error code means that the fixing unit motor is unable to turn, it could be just a paper jam, or the bearings have seized, either way you will have to strip down the fixing unit, it is very common on this model for the lower roller bearings to seize. Good luck
Sep 06, 2014 | Cannon Office Equipment & Supplies
Cannon error code e000001-0008
What model is this? if its an iR, then its fuser error, needs replacing, not warming up.
Sep 05, 2013 | Cannon Office Equipment & Supplies
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
The machine shows the E007 system error what is the solution for it. machine is cannon iR2116J photocoyp machine
the error E007 means - fixing film rotation error.
If you are not a tech you must call for one. He could replace the broken part for about 2-300$.
Jun 03, 2011 | Canon iR 2016i Black and White Copier
Please give me ip address canon (ir 3300.)
Below is the Cannon link page to the Image Runner IR 3300E and 3300EN model. Go to the bottom of the page and pick the correct model number and click on the download and driver page.
If you found this answer helpful, please remember to leae positive feedback.
Thank You,
Brian
Mar 20, 2011 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
My xerox machine cannon IR 2020 shows a system error E007. How can I solve it? Please describe step by step.
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 11, 2010 | Canon iR 2022 Printer
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
106 people viewed this question
jasbo
jasbo
