Question about Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair
I have a Jazzy 1121,when I went to plug it in to recharge it, I noticed the lights weren't flashing like they suppose to and plus while it was plugged in I was still able to move the chair, when I shouldn't been able to do so...what do you think the problem might be? Thanks!
  • 103 Answers
The chair is not recognizing the charger. If it is an off board charger, check the pins in the conncector to be sure that one has not been pushed back. On board, check to see if the amp meter moves at all.
Posted on Nov 06, 2009
3 Suggested Answers
SOURCE: Jazzy 1121 power chair won't go
It may not be the joystick. I have had the same problem before. The edel cable that goes from the joystick to the back of the wheelchair could be bad. You can try unplugging it and plugging it back into the joystick. Check the prongs on the cable and make sure their not broke. You can also try flipping the switch that is located down by the charger under the chair. The cable is around $200 and the joystick is quite a bit.
Posted on May 16, 2009
  • 692 Answers
SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Posted on Oct 23, 2010
I have a jazzy 1121 and my seat moves around a little bit. How can I lock it?
Pride Mobility Jazzy 1121 - USA TechGuide
www.usatechguide.org/itemreview.php?itemid=570
19 posts - ‎16 authors Medium Back Seat Contoured Medium Back (standard). ... Comments: My jazzyscooter goes forward and side to side but the reverse makes a quick .... Strengths: Tough chair - town I live in doesn't have many curb cuts, but chair will climb ....Maneuvers poorly through (Handicap) doorways, due to rear locked caster wheels.
Nov 29, 2015 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
My jazzy 1170xl plus won't move. When I power it on the lights come on like there supposed to but as soon as I move the joystick the battery level lights start to flash rapidly. 9 of the 10 lights...
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Apr 29, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
I have a jazzy 1121 power chair and the lights on the joy stik are flashing and the chair just stoped working
Doggy count the number of flashes ie 4 flashes pause 4 flashes if you are not getting any pauses
what lights are flashing the battery level lights or the speed lights? Are all the battery level lights flashing or there are 3,4,5,6 or 7 etc. lights flashing? if you are getting a pause between flashes the number of flashes will tell you the error. Your owners manual should tell what each code means. Hope this helps
Mar 06, 2011 | Health & Beauty
My jazzy 1121 is not charging. I plugged it in last Wednesday and have checked several times. It has not charged.
candy probably a battery issue but it could also be a charger problem also If the batteries had gotten really low then the charger is not designed to pickup really low voltages. If possible have your provider (Where you got the chair) check the batteries and charger for you Hope this helps
Feb 10, 2011 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy 1121 power chair won't charge when plug in to charge chair can move when you use joystick
Oct 22, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
1 red and 3 amber lights flashing after stopping and goes around in circle on a jazzy 1121 powerchair
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
The powerchair going in circles may indicate a motor is bad and needs to be replaced.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Aug 23, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
I have a Jazzy power chair on loan and there is no instructiion book. How do I recharge the chair? I know I plug it in but do nmot know if it is actually recharging, Thanks
Be sure to charge the chair at least 8 hours each time. If you use it charge it. If you charge it less than 8 hours than it starts taking away from the life of the battery.
Nov 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Apr 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair Logo
143 people viewed this question
Top Heavyduty Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Heavyduty Health and Beauty Expert? Answer questions, earn points and help others
