Question about HP PhotoSmart C4480 All-in-One Printer InkJet
My printer doesnt print
When i try to print paper goes straight threw it
  • 137 Answers
Sounds like the driver may have gone corrupt
Try to uninstall and reinstall the drivers/software.
Be sure that the device is not connected to the computer until the software prompts you to plug it in
If this solution has helped you, please take the time to rate me.
Posted on Oct 04, 2009
Why does my epson 1400 keep loading paper straight threw instead of printing?
I have had this problem several times. The culprit is the feed wheel which can get covered with paper dust and it loses it "bite". Epson sells cleaning sheets that are tacky and when run through the printer remove this "dust". I have also resorted to taking a piece of scotch tape and carefully sticking it to the rubber take-up wheel and then gently removing it to pull the paper dust off with the sticky tape. Another problem can be because of not setting the paper type correctly. Check to make sure that the paper type set for the printer is the same as the paper you are feeding.
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Why does my epson 1400 feed paper straight threw instead of printing?
first, are you on a screen that has text on it to print. say a word document? Not a web page. second, how long has the 1400 been sitting before this happened? if a long time then the ink head may be clogged. Try printing in gray scale only and then in color and see if the same thing happends. Third make sure all print tasks are cleared. normally in the bottom right hand corner you will see a printer icon. if youclick it it will tell you how many jobs are waiting. clear them all. by pausing and then canceling them. (if they are there.) if none of those exist then look for the ink pad on the inside of the printer to the right. ( you will have to see if the head is moving left and right to do this.) if the printing head is moving left and right and you dont see anything stuck like paper and such in the machine then you need to find out if the black foam on the right where the print head parks when its done and shut off is wet or not. this entails watchin the print head go to the left and then shutting down power to this printer by unpluggin it. (this is not a switch off it needs to be unplugged from the 110 outlet) then if you can feel by a Q tip if you donw want to get your hands inked and see if it comes up with colors and black. if it does not then the ink heads or ink or both are dried. then do a search here on Fixya to look for clogged ink heads
When trying to print a document, the paper goes in crooked. Then my printer says there's no paper. Of course, there is plenty of paper and it's straight before headed to the printer.
If it goes in crooked, there could be a slight paper jam. Take the top off or open it up anyways and check the feed roller to make sure it is not sticky or jammed.
Nov 10, 2010 | Office Equipment & Supplies
Paper not feeding into printer straight When printing the paper doesnt feed into printer straight anymore.
Firstly I would check the paper guides on the paper stand, then check the path, turn it upside down and look for debris, I once found my childs sticky sweet in mine. Then try to clean any rubber rollers.
Oct 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Every time i try to print the my paper goes in sideways and doesnt feed into the printer properly what wrong????
There is almost certainly something in the print path that is obstructing the paper. Check to see if there isnt some old paper or something dropped in the paper input.
Sep 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
LexmarkX1240
sometimes the print heads will become blocked. Take the catridges out and put a piece of toilet paper across the head and see if ink bleeds through. if not try moistening some kitchen paper and gently cleaning the heads.
Nov 13, 2007 | Lexmark X1240 All-In-One InkJet Printer
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
