Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Generic problem for all Refrigerators
Ge profile refrigerator door handle is loose
mrferley on Dec 22, 2007
how do I tighten the door handles on a ge profile refrig? how do I get to the screw?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
May 15, 2009
-   I have the standard stainless GE french door fridge but have GE Profile range. Can I replace the std door handles with profile handles? Are they interchangeable? -   joephu
Apr 23, 2009
-   What do you do if the screws will not tighten?  -   tigerjo67
Apr 11, 2008
-   same thing here-   Guest
Jan 02, 2008
-   Door handle is loose - looks like I have to remoce all th screws beneatht the gasket on the inside of the door. NOt sure if this is the easiest way to do it. Any ideas anyone?-   fettermann
Best Solution
posted on Apr 09, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
On the GE Profile, the handle is mounted to two small screws. To detach the plastic housing, you must press on the two connection points (the base and top of the handles) and slide the handle up or down (takes some effort). The handle will come off and you will have very easy access to these 10mm screws.
Solution #2
posted on Oct 10, 2008
Helpful)
sqwuirt
Rank: Apprentice
Rating: 88%, 12 votes
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #3
posted on Jan 16, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the screw is in the small hole (ie) for the freezer section look on the bottom side of the handle - or on the inside of the fridge handle.
Related Problems
I had my GE side by side for about 2 years. Things have...
GSH25KGRBB i got this frig it click on and off and on and...
I bought the defrost heater unit and the connector does not...
Can you Help with these Refrigerator problems?
Roper Refrigerator is Not Cooling...
Solve
Yesterday, I noticed the ice in the ice maker melting and the temperature dropping on the... (More)
Ice maker is not making ice, the ice...
Solve
Ice maker is not making ice, the ice is just stuck in the try and is not popping out.
I have a Dometic fridg in my 2005...
Solve
I have a Dometic fridge in my 2005 Lexington motorhome. When I try to start my fridge on auto the... (More)
My sub zero 650 isn't making ice
Solve
My "service ice" light is lit on my 650 and it isn't making ice. How do I fix this - I am... (More)
water dispenser won't stop dripping
Solve
Sponsored Links
Describe your Fridge problem:
Select a Category:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 2825
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 440-8583
http://WWW.SUBZEROLOSANGELES.COM SUB-ZERO...
A1 Service
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
