Question about D-Link AirPlus DI-524 Wireless Router
Router to use as relay.
When I have a neighbor willing to let me share his wireless network, the signal isn't strong enough where I have my computer.  I've heard there are some routers you can configure as a relay, that aren't too expensive.  I'd like to find a router with detachable antennas that has good range for connection to a wireless network, and at least two LAN ports, so I can wire it to my two computers, and network between them as well. I don't need a wireless connection between the router and my computers, as they rarely move.
Can you suggest a  brand and model (other than Buffalo's, which are no longer available) that would be good for this?
  • 32 Answers
Linksys WRT54GL with DD-WRT firmware. Now, DD-WRT will void the warranty, but it has been incredible for my uses when configuring WDS. A the WRT54GS has also been said to be an excellent router, but I cannot say.
Posted on Dec 31, 2007
  • 35 Answers
I would also recommend a WRT54GL with DD-WRT firmware. Since I own one, I can confirm that's it's a very stable and flexible router. Flashed with DD-WRT firmware (BTW, on the GL, flashing with DD-WRT does not void the warranty because the Linksys firmware it comes with is opensource anyhow), this router if very customizable I use it as a server and internet sharing solution, though I have my own high speed internet ADSL modem hooked up to the WAN port, so I don't get internet through a wireless connection like you need to do.
Posted on Aug 05, 2009
How do i setup my alfa usb adapter to my neighbors router
Plug in the adapter, install the driver, from the wireless icon in your system tray join your neighbors wireless network. That is of course assuming your neighbor knows about it and it isn't password protected.
Jul 13, 2012 | Computers & Internet
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
I wont to play game in lan with my home frends bat my computer canot find a lan .the game is full . my net is with dinamic ip..what i can do?thanks
D-link router provides signals through cable wired connection where each persons computer shares signals from the only computer that has network services. For example, one of the computers that has the internet on which router is connected either has capacity to network several additional computers or not. Usually the server computer that has connections with ethernet cables makes sharing signals possible beyond dial up phone line networked cable conections.The routers splits signals between computers requesting connectivity only becomes possible when enough capacity exist to several computers. The type of network strutures makes the link possible. For example, D-link router should allow to network more than one computer else another router that makes signal expansion possible is prefered. Circumpectively, ascertain that the computer from which video game is installed has the expansive capacity either in cables connection ports, wire links where router becomes the location where each device derives resources.
Feb 22, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Using linksys wrt54g router i using the wired section with two computers and the signal only dropping
There are many causes for poor wireless connections, and many solutions:
First of all, give your network a unique SSID. Do not use "linksys". If you are using "linksys" you may be trying to connect to your neighbor's router. Also set "SSID Broadcast" to "enabled". This will help your computer find and lock on to your router's signal.
Poor wireless connections are often caused by radio interference from other 2.4 GHz devices. This includes wireless phones, wireless baby monitors, microwave ovens, wireless mice and keyboards, wireless speakers, and your neighbor's wireless network. In rare cases, Bluetooth devices can interfere. Even some 5+ GHz phones also use the 2.4 Ghz band. Unplug these devices, and see if that corrects your problem.
In your router, try a different channel. There are 11 channels in the 2.4 GHz band. Usually channel 1, 6, or 11 works best. Check out your neighbors, and see what channel they are using. Because the channels overlap one another, try to stay at least +5 or -5 channels from your strongest neighbors. For example, if you have a strong neighbor on channel 9, try any channel 1 through 4.
Also, try to locate the router about 4 to 6 feet above the floor, in an open area. Do not locate it behind your monitor or near other computer equipment or speakers. The antenna should be vertical.
Also, in the computer, go to your wireless software, and go to "Preferred Networks" (sometimes called "Profiles" ). There are probably a few networks listed. Delete any network named "linksys". Also delete any network that you do not recognize, or that you no longer use. If your current network is not listed, enter its info (SSID, encryption (if any), and key (if any) ). Then select your current network and make it your default network, and set it to automatic login. You may need to go to "settings" to do this, or you may need to right click on your network and select "Properties" or "settings".
If the above does not fix your problem, download and install the latest driver for your wireless card.
Some users have reported improved wireless performance by switching to WPA encryption.
If you continue to have problems, try the following:
For wireless g routers, try setting the "Transmission Rate" to 54 Mbps.
If you still have trouble, download and install the latest firmware for your router. After a firmware upgrade, you must reset the router to factory defaults, then setup the router again from scratch. If you saved a router configuration file, DO NOT use it.
Aug 24, 2010 | Linksys Wireless-G WRT54G Router
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do i establish a wireless connection with my router?
I would start by reading the manual
please download the manual, unzip and follow the procedure to set up your router.
now your question is a simple question yet a complex one to detail here but basically what you do is this
what you need
1.laptop or desktop equipped with a wireless network card. Yo can't stablish a wireless connection if your computer does not have this key component.
2. set up your router so that is whithin range. meaning that your router name should come up in the list of wireless networks detected by your wireless network card in your computer, the signal should be strong enough so you can connect to your router wirelessly.
what you do in a nutshell is this.
1. usually routers come ready to be used out of the box, so if you are not concern about someone else using your router to connect to internet you can just
1. connect your router as follows
a. plug your wan cable coming from your modem to the wan port on your router (that's the cable that has the internet signal).
b. power your router.
2. in your pc, open the wireless network manager (the one installed with the cd that comes with your router or the one that windows has, either one should work) and look for the wireless networks being broadcasted, there is a list and your router by default should broadcast its name "d-link". since the d-link router is the one in your house it should be the one that says "d-link" with the highest signal in the list.
3. double click on that d-link router and you should be connected.
important: in the manual there are instructions to change the default name of your router which is always a good idea. the techincal name for your router is called the SSID, that's the name of your router and by default that name is "d-link" on dlink routers.
if you are concern about someone else (neighbors, war drivers) using your router you may also need to set up a password (psk key or passphrase) and encryption (wep, wpa, wpa2), I suggest you set wpa2 as it's the strongest encryption and will make sure that if signals are picked up by a neighbor or a war driver or hacker your info remains private. your manual should walk you through the process.
as you read your manual feel free to ask more questions and I will follow up with you!
I hope this gives you a good idea on how to start
Apr 19, 2010 | D-Link Xtreme N DIR-655 Wireless Router
We just bought a new emachine, Acer E627, with windows 7. I cannot connect it to our home network using a D-Link DIR-655 router. It has always worked fine. Other computers can connect to OUR network, we...
WPA is not very stable and I have seen many problems with this. Simply change router setting to be configured with WEP and use a good strong password in hex 0-9 and a-f . WPA is horrible any way, and who the heck is gonna sit out side your home to hack it? It is not a WIN 7 problem but more like aging encryption.
Feb 07, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Very week signal from belkin wireless G router
check you office or home erting in your installtion location , because same time power is not perfect comes to then that type of problem ......check your earthing fist ....ok
Mar 23, 2009 | Computers & Internet
Need help using router
First of all your neighbor must be able to reach your signal. When they start up their wireless application they must be able to see your SSID, and have enough signal strength to actually connect and do meaningful work. This might be the case already, or you may need to put in a repeater closer to your neighbor. You r neighbor could also purchase an external directional wifi antenna from radio shack to improve reception. I have used Cantennas (look like a Pringles Can) before and they work ok.
Once you have signal then you just need to give your neighbor the password to your wifi network for them to enter into their network application. This password was setup when you setup the wireless network. You probably wrote it down, or it is a common password that you use.
The rest should be seemless, depending on the signal strength.
Nov 11, 2008 | Linksys Wireless-G Broadband Router
Router
I prefer to test these problems in a step by step manner.
Have you tried to connect either the laptop or any other computer to the internet using an ethernet cable instead of wireless?
If so could the wired computer use the internet successfully?
If so skip down to Wireless Considerations
Can you provide a web link to your internet service providers (ISP) help or support web site? If necessary will you provide you location city and state if required to access the ISP's help/support site?
Can you confirm the make and model of your router as a Netgear WT624SC?
Can you provide the manufacturer and model of your wireless adapter or the model of the Mac Laptop if it has a built-in wireless adapter?
Given that you now have a wireless network are you interested in discussing security options to protect you from people accessing your wireless network from outside your home? (if the signal is strong enough -- from inside home I can see two of my neighbors wireless routers not to mention my own)
Dec 13, 2007 | NetGear Super G WGT624SC Router...
D-Link AirPlus DI-524 Wireless Router Logo
627 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
