Question about YouTube Computers & Internet
Golf cart won't go.
I have a Ruff & Tuff electric golf cart (48 volt - 11 hp - 400 amp controller) fully cherged batteries. When I press the pedal I get the normal clicking sound but cart does not go - forward or reverse.
What can I check next?
weblord
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
blueextc3221
  • 15935 Answers
SOURCE: trying to power a amp with 16 volts. possible?
Golf carts do not have a charging system. If you are going to use battery power only, why not just add (1) 12V car battery instead of (2) 8V??
MA Audio runs (ran) their bench tests @ 17V. All the power ratings advertized are at 17V.
The power supply for the hk4000D is unregulated. So the more voltage = more power.. 8V-16VDC.
  • RMS Power @ 14.4V
    • 1800W x 1 @ 4 Ohm
    • 3600W x 1 @ 2 Ohm
  • RMS Power @ 17.0V
    • 2000W @ 4 Ohm
    • 4000W @ 2 Ohm
    More input voltage means the amplifier will have to work less hard to make power.
    Don't expect the amplifier to work for very long however. the current drain on a class D amplifier is huge. There are no on-board fuses protecting the power supplies, so be sure to have at lease a 150A power line fuse.
    With 150A current draw - even with the amplifier at 1/2 gain - expect to get 10.6 minutes of listening time from your 16 volts before recharging - also note, the amplifier MUST see 8V to turn on, there is a built-in voltage sensor that will shut down the amplifier if voltage is too low.
  • Posted on Jan 23, 2009
    • 6 Answers
    SOURCE: electric golf cart, mash the pedal won't move
    you have a broken belt .
    Posted on Jun 03, 2009
    SOURCE: 48 VOLT GOLF CART ''BATTERIES'' HELP !!! CURIOUS
    Sams club $77 each
    Posted on Jul 24, 2009
    shocktroop40
    • 155 Answers
    SOURCE: ez-go golf cart press accelerator pedal and nothing happens
    The first thing I would do is lift the seat and check the battery connections. Those batteries are notorious for corrosion at the terminals. Make sure every connection is clean and solid, as in no loose, corroded or frayed battery cables. Next, if the batteries check out, toggle the run/tow switch, also under the seat to make sure it is fully engaged into the run position, and finally check the forward/reverse lever to make sure the connections are clean and tight.
    Posted on Aug 03, 2009
    HOW TO GET THE PART NUMBER FOR THE REAR BRAKE SHOES FOR MY RUFF AND TUFF GOLF CART
    E-Z-GO Golf Cart Brake Shoes - Genuine E-Z-GO Parts and Accessories
    https://shop.ezgo.com > Shop > Parts > Brake Parts > Brake ShoesOEM Golf Cart Brake Shoe 4084 ' Single Shoe. Fits 1996-current E-Z-GO Golf Car and Utility Gas & Electric Vehicles. Item #: 648037. $24.70/ea. Spring- Shoe Return- LH (Blue). Used on 1996-Current E-Z-GO Gas & Electric 4/6 Passenger Shuttle, ST Express, 875, 881, 950, and Cushman Titan Vehicles; in addition to ...
    Nov 30, 2017 | Cars & Trucks
    I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
    Troubleshooting a golf cart - APLawrence.com
    aplawrence.com > Miscellaneous
    Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
    Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
    https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
    Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
    About Golf Cart Battery Chargers ' Golf Cart Talk Blog
    www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
    Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
    Basic EZGO Golf Cart Problems And How To Fix
    Feb 09, 2016 | Golf
    Charger wont kick off after fully charged.
    Charger won't shut off - Buggies Gone Wild Golf Cart Forum
    www.buggiesgonewild.com > ... > Electric Club Car
    Sep 27, 2010 - 7 posts - ‎2 authors
    But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
    Sep 5, 2011
    Club car 96 battery charger not turning off
    Aug 30, 2011
    2001 Club Car Charger Won't kick off
    May 31, 2011
    48v club car charger wont shut off
    Apr 11, 2009
    More results from www.buggiesgonewild.com
    About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
    Jan 24, 2016 | Golf
    Club car golf cart will only travel 3 ft. then cuts off.
    See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
    *NOTE: Not all carts have this switch, check with the manufacturer.
    Nov 20, 2008 | Golf
    Computers & Internet Logo
    484 people viewed this question
    Top YouTube Computers & Internet Experts
    Rizwan Hanif
    Level 1 Expert
    Michael Terence...
    Michael Terence...
    Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
