Question about Garden
Hushqvarna chainsaw 36/41 brake sidecover where do i get one?
    President:
  • 2,220 Answers
You can find the part number here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
A google search for "Husqvarna YourPartNumber" should provide ample outlets. GL
Lou
Posted on Oct 05, 2009
  • dontbother10
    dontbother10 Oct 05, 2009
    The serial number is the key to the correct IPL.
    sn 06 1500198
    06 = year produced
    15 = week produced (March)
    00198 = 198th unit produced by Husky that week.
    It might be a good idea to save a copy of the IPL.
What is the chain brake an where
not on the older chainsaws
newer ones it s normally the black lever you hold
Check the Chain Brake
Make sure the chain brake is working properly by putting the chainsaw on a stable surface. Release the chain brake, squeeze the throttle and then activate the chain brake by pushing your left wrist against the kick back protection without releasing the handle. This should cause the chain to stop rotating immediately.
source
http://www.tractorsupply.com/know-how_home-garden_outdoor-power-equipment_chainsaws_the-basics-of-using-a-chainsaw-for-beginners
can be part of the centrifical clutches
Apr 30, 2016 | Garden
Tip
How to get the chain brake reset so ou can get the sidecover back on
If you have removed the sideplate on your chainsaw with the chain brake in the locked position, you will have a very hard time getting it back on without destroying the brake band. If you have done this try this solution. First remove the bar and chain fronm the saw, then start putting the side cover on, use one of the nuts on the front screw.As it comes in contact with the ratcheting part of the hand break make sure you push the chain brake handle forward while tightening the front nut I mentioned. when the nut is snug, pull the brake handle back to reset the brake, You will hear it click into place. then remove the side cover and re install the bar and chain. your good to go/
on Dec 15, 2009 | Garden
Why does engine leak oil?
blown seal on engine or a blown gasket make of engine horse power vertical or horizontal
Sep 13, 2014 | Garden
Changing the chain on chainsaw
remove the 2 nuts holding the sawdust strut/sidecover and remove side cover. remove chain and bar. clean the chain slot and oil holes on bar. install new chain over bar and place remainder of chain over chain sprocket.back off chain tightener until chain and bar fit. reinstall side cover.
Nov 24, 2013 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Where is the battery?
1. It should be under the seat just about a foot behind the tank so remove the seat.
2. Some models have the battery under the sidecovers if the bike has sidecovers.
Aug 04, 2012 | 2008 Suzuki GSX650F
How do you get the sidecover back on over the clutch drum on a McCulloch MAC 335 Chainsaw? The sidecover does not seem easy to remove or put back on which is annoying when you need to put on a new chain....
Hi Hamish,
You don't remember how you took it off? Well, that happens sometimes... :>)))
Pull the chain bar away from the sprocket as far as you can move it, then rotate the adjustment knob handle into its original position. You may have to pull the chain brake back if you bumped it into the lock position while working on your saw.
If you need any more help with your chainsaw, ehow.com has full explanations on just about everything. Just type in "how to ..." with your problem and articles and videos are available.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 25, 2011 | Garden
On a 2000 Ultra, where is the pressure switch, not the sender?
Pressure switch for what? Oil or brakes. If oil, right behind the rear brake pedal mounted on the engine crankcase, it points forward, and has only one wire come off it. It's about 3 1/2" long and about 1" in diameter. Brakes, it's usually near the right frame junction under the sidecover or just below it.
Apr 06, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
How to replace chainpoulan pro 18"
First lay the new chain out with the cutter teeth facing forward on top. You should wear gloves because it takes very little to inflict a deep cut with these chains.
Take the tool that came with your saw and loosen the two nuts (don't take them off yet)that hold the sideplate on over the chain. Leave the saw setting on its bottom.
When the nuts are loose take the screwdriver end of your wrench (or a screwdriver) and loosen the chain quite a bit. Wearing the gloves, make sure when you pull it forward it moves very loose.
Now take the two sidecover nuts all the way off. You'll see how the chain goes arpound the sproket. Push the bar back toward the sproket until it is loose enough to remove the chain.
The bar will come off too, and it is important to note the small nub that goes in the tensioning hole on the bar near the bottom of the saw, fairly close to the sproket. Keep the chain straight; I hang mine on nails driven into the wall in my shop. You can get them kinked up so that they seem they'll never straighten out.
Take this time to clean all behind the sidecover itself, and the entire enclosed area. There will be sawdust, twigs, etc. I blow mine off with compressed air, but protect your eyes. Take something, toothpick, Qtip, or the like and clean the groove all the way around the bar, including the oil holes near the rear.
You should now be ready to insert the new chain, putting the bar with the slot lined up with the sidecover bolts, and gently get the chain on the sproket. This may take a couple tries before you get it right. When it is on (you'll see you have to hold the bar up or it will tip too much) hold the bar in place with the tightener in the hole, and slip the side cover back on. Tighten the nuts just enough to hold the bar in place, then tighten the chain tension screw, while holding the bar. Tighten the side nuts more, until the bar is held in place.
When it is just tight enough to hold the bar but not prevent the bar from moving forward when you tighten it, tighten until you can still move the chain, but there is no visible slack in the chain. You should be able to grab the chain at the bottom and with moderate force pull it away from the bar about a half inch.
I like to pour a little oil on a new chain so it has plenty of lube. The chain will stretch because it is new. Run the saw at about 1/3 throttle for a minute, holding the end close to something to make sure the chain is throwing off a fine thread of oil. Then run it at 1/2 speed about another minute. Rev it a few times, make a practice cut or two, and it should by now need another slight tightening.
Sirwriter
Jun 07, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i access the battery on 2000 v-star 1100 classic
Hey pal, your battery is either behind one of your sidecovers or under your seat. Start w/ the sidecovers 1st....when you find it you don't have to remove it to charge it, but if it won't hold a charge (long term storage) then your gonna pop for a new one.....Good Luck to you friend....Tim
May 11, 2009 | 2001 Yamaha V Star 1100 Classic
I need instructions on how to put a battery in my 1991 Intruder 1400!? My son is away and he usually does it for me. thanks Joe D
Hey Joe ! Batt is either behind one of the sidecovers or under the seat. Start w/the sidecovers. Remove red and black wire from battery and pull it out. Make sure new batt has been trickle charged overnite...reinstall is opposite of removal, make sure red wire is on positive+ and black negative- Good Luck to you friend....tim
Apr 28, 2009 | 1991 Suzuki VS 1400 Intruder
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
