Question about Kenmore 24032\24036 Top Load Washer
I need instructions on replaceing the motor coupler on kenmore washer series 80 mod 110-24822200 typ 111
  • 523 Answers
First you'll need to unplug the unit; after which I'd shut down the water supply and remove these. If against a wall you'll need to move the washer 3-4 feet from it to allow you to tip the washer back. No reason to lay it all the way down just on a heavy angle so you can access the under belly (be certain it will not come back down on you) I expect there is a noise shield you'll have to pull from its tabs. After which you should have a clear view of the motor and see where the remains of your older worn coupling are. I believe on that unit you'll unplug the motor (look for an electrical connection) then there should be two (2) pieces of metal that act like heavy snaps holding the motor in place, using a screw driver or such "un-snap" these pieces (be careful as once there loose the motor is too) this will allow you to drop the motor and gain full access to the coupling. This job should take @ 30 -45 minutes, take your time, keep it clean, keep it safe and in doing so you'll have saved you some good money.
I hope this may have helped,
Tom
Posted on Oct 04, 2009
2 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: i need instructions on replaceing the motor coupler
Check the video at the following link and see if it is of assitance to you in changing the coupler. Sure hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
I have a Kenmore Series 80 washer and the tub
i would check the motor coupler
it sits behind the motor before the transmission
this model
thre piece part that drives the transmission
Oct 15, 2009 | Washing Machines
My kenmore 80 washer spins just not enough to get as much water out as it should. not even 4 towels model 110-24872300. serial cr 10100 91 type 111
you may want to check, the motor coupler,
this is a three piece part, it sits between the transmission, and the motor and controls the speed
just by being in place..
Oct 13, 2009 | Kenmore 24032\24036 Top Load Washer
Oct 04, 2009 | Washing Machines
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
How do you open the console on a Kenmore 80 Series Washing Machin
To replace a motor coupling on a Kenmore top loader, follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Included are all the step-by step instructions you need (including how to open the console). If you still have questions, or require additional assistance, please let me know. I hope this helps you.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
Washer leaks and tub won't empty in the beginning of the cycle
check your hoses all the connections. you'll have to pull the part with the knobs off to do this inside. If it isn't turning, but the motor runs, it might be the coupler in the bottom of the washer connecting the motor and transmission.
Feb 21, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
99 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
