Question about RCA P52930BL 52" Rear Projection Television
Wording is triple everything shows up triple and all is a different color
Is a triple square socket the same as a star bit
the star bit or torx bit as it is commonly known is different from the triple square socket.
here is a Wikipedia site that explains torx, if you scroll down about 1/2 way, on the hight there is a chart showing the different types of drivers & what they look like.
http://en.wikipedia.org/wiki/Torx
Nov 14, 2014 | Electrical Supplies
Picture shows 3 colors on everything.example.if there's a hand.there's 3 hands and each is a different color Blue .red.green
There are actually 3 projectors inside, each handling one of those three colors which, together, make all the other colors. This is called "out of register" where they are aiming slightly differently. These need to be adjusted.
Jul 31, 2014 | Televison & Video
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
My tv overall is blurry, but when I click menu to mess with the settings, only the picture of what I'm watching, and the highlighted word is blurry, but everything else is clear, video games and movies n...
Some of your electronics parts were worn out. Like capacitors may have leaks that need to be replace
as use stated that the word focus were very clear it means that your tube is still okay. or you adjust the focus knob on the compartment. To tune in the 3 colors.
Jan 01, 2011 | Toshiba 57H82 57" Rear Projection...
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Hp printer 7450 won't print colored text from a word document. test page shows colors on the windows logo flag. changed the ink cartridge....color one that is....no help i will try to print something else...
It may be set for grayscale (black and white) in the print properties. Go into the print properties in Word and look for a color or black and white setting, either under Color Management or Advanced. Set it for color, and then print your color document.
Jun 19, 2010 | HP Photosmart 7450 InkJet Printer
Different color shadows. Double or triple vision
replaced convergence IC.what is the model#?
Oct 04, 2009 | Televison & Video
Word processor shut down
A website has a lot of writing that is not seen. It tells the browser (IE, FireFox, etc...) how to show it. Some examples are: bold, different colors, different sizes and more. When you copy, you are including a lot of this hidden code. This could be causing your word processor to 'cough'. When you PASTE SPECIAL, only the text gets pasted.
Sep 29, 2009 | Dell Inspiron 531s Desktop Computer
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
