Question about Whirlpool Washing Machines
When i turn my whirlpool awod 5726 on to do a wash cycle it comes up with error code f23
4 Suggested Answers
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
SOURCE: Whirlpool AWO/D 7740 error code F23
error code f23
Posted on Oct 17, 2010
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Whirlpool F23 code error
f23-whirlpool-washing-machine-error-code.jpg F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
Resetting the program may clear this error but unlikely.
  • Check the pressure switch or sensor for operation and electrically
  • Check the wiring from the main electronic control card to the level sensor
  • Check all connectors between the main controller and pressure switch
  • Run test program
  • Also see F08 and F12 as heater failure can cause this error to occur
Aug 31, 2014 | Washing Machines
F23
PRESSURE SWTICH ERROR
The wash level and level heater safety are switched on at the same time F23
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to pressure switch and Central Control Unit (CCU).
3. Check connections of the CCU board within the housing.
4. Check the pressure switch for worn or failed conditions .
cheers
Jul 18, 2017 | Whirlpool WFC7500VW Washer
F23 on whirlpool washing machine
Seems that your heater has failed. Check continuity of the element, wiring to the element and test the voltage from the controller panel board .
Click this link: error codes
Jul 04, 2012 | Whirlpool Washing Machines
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
The error F23
Try this
Hope this helps .
Feb 21, 2009 | Whirlpool Washing Machines
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
Jul 18, 2008 | Whirlpool Washing Machines
Replace door seal on whirlpool model857037015500
Whirlpool AWOD 5726. How do you replace the door seal?
Jun 07, 2008 | Whirlpool Washing Machines
Washing Machines Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
