Question about Motorola Mobility Hint QA30 Cell Phone
My motorola hint phone says "unauthorized charger"
My motorola hint phone suddenly wont charge, saying "unauthorized charger". It is the same charger that came in the box with the phone!
U have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Posted on Jan 15, 2010
My dogs chewed up my charger. i figured id connected to my lap top and let it charge that way. but it keept saying un.charger. after i put in a memory chip i pluged it in again and it charged ok. remember to make sure your usb connection is on the mass storege option on your settings. not a solution to the problem. but its an option.
Posted on Jan 19, 2010
I agree though. I have had the Hint for a year and I have had multiple problems with it and just yesterday my phone started saying "Unauthorized Charger" and I have been using this charger for months!!
Posted on Jan 14, 2010
I recently dropped my Motorola hint and started receiving the Unauthorized Charger message , My memory card slipped out of position. CHECK YOU MEMORY CARD !! thank you...
Posted on Oct 27, 2011
    New Friend:
I Have a Motorola Theory and I had gotten the message about unauthorized Charger so I did what someone on this page said about turning it off then pulg in the charger in once I'd did that it started changing then I turn the phone on and its still charging
Posted on Mar 06, 2013
My phone just started that and i am using the charger that cam with it and i turn it off and try it my phone is the rival.
Posted on Feb 12, 2010
I just had the same prob and i found the solution the only way for you to fix it is to by a motorola charger the motorola phones espesaly the hint does not like other brand chargers so go and buy a motorola brand charger and it will work like a charm dont let them talk you into a dif brand charger i made that mistake
Posted on Dec 21, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Motorola Mob... Master
  • 1,001 Answers
Chornic Quick Charger 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Nov 28, 2016
I have a motorola glass. And the charger usaully always work. Well in my new dorm I plunged in my phone for it to charger and it said "unauthorized chager" but back at my other dorm room it didnt have any problem chargering. and then I plung it in to my car charger it said the same thing and now my phone sometimes wants to charge but at night it really doeant wnat to.
Posted on May 09, 2012
When I plug in the charger it wont charge Im not getting like unauthorized charger message it just wont charge
I advice you try get a similar charger to charge your phone, if the similar charges your phone, it means your charger is bad and will need to get another charger or the phone.
But if it did not charge and you still get the same message, it means the charging port on your phone is the problem, the charging port on your phone is bad and can not read the charger, so you will need to replace or change the charging port on your phone. Doing thi will solve the problem on your phone.
Take care.
Jul 19, 2010 | Motorola Mobility Hint QA30 Cell Phone
Plugged my charger into my phone and it says unauthorized charger. It has worked fine until now.
That happens because of dirt, debris or moisture in the charging/USB Port, use a can of compressed air (Duster) to clean out the connection and try it again, also remove and replace your battery in your phone to initiate a Soft Reset to your phone.
Jun 13, 2010 | Motorola Mobility Hint QA30 Cell Phone
When i try to charge my motorola hint q30 it says unathorized charger what do i do
Some non-motorola chargers (usb cables) do not give the proper voltage which give this error.
You can try shutting your phone off, this can be a way around the problem since it should still charge as it is off.
Mar 09, 2010 | Motorola Mobility Hint QA30 Cell Phone
Unauthorized charger
Is the charger the one that came with it?
Jan 19, 2010 | Motorola Mobility RAZR V3m Cellular Phone
HimoronI
Could be you have a battery issue.
Mark
Motorola Support
Dec 26, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Whenever i plug my charher into my motorola razor it says unauhorized charger.
The "unauthorized charger" message is hence telling you that the power
output of your charger is significantly lower than a Motorola charger
would provide. It may or may not still charge the phone, you'll have
to try it to see. If it does charge the phone it will take longer to
do so than a higher power charger would.
Hope this helps. =)
Oct 20, 2009 | Motorola Cell Phones
Unauthorized charger everytime i plug it in.
There may be a problem with your charger output. Do you have another charger you could try?
A temporary workaround is to reboot the phone with the charger still attached. It should now say "Authorized" and start charging.
Jul 25, 2009 | Motorola Mobility W385 Cellular Phone
Motorola Razr phone charger gets message, ''unauthorized charger.
The problem was in the point of connection between the charger cord jack and the cell phone charger receptacle.  By moving the jack within the connection I was able to resume charging.  The connection may have become faulty as a result of heavy usage.
Feb 15, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola razr wont charge
try to do a master reset/ have the mobile charger usb port service
Dec 29, 2007 | Motorola Mobility RAZR V3
H500 WON'T CHARGE
Motorola devices use proprietary USB cables on their chargers. There is a resister on the cable that has no purpose other than to let the phone/headset know it is a "Motorola Authorized" charger, which is a complete load of hogwash. A normal USB cable, hooked to any generic PC, will not charge them (says unauthorized charger on phones) UNLESS the Motorola driver is loaded on the PC, which magically makes the PC a Motorola Authorized USB charger.
Bottom line: use the Motorola USB charger that came with it, and then write a nice love note to Motorola saying how much you like their product's "feature".
Nov 01, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility Hint QA30 Cell Phone Logo
11,466 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
