Question about Saeco Classico Espresso Machine
Steam jet in Saeco Classico
Steam p'rello does not shoot out enough for a bit then stops before milk is frothy enough...
  • kbleicher May 26, 2008
    Same problem
  • Saeco Expert
  • 223 Answers
Try Descaling your machine. A lot of times calcium will form on the inside of the boilers and on the heating elements in espresso machines causing heat transfer issue and clogged lines.
If the heating element cannot transfer enough heat fast enough then your steam will run out.
If you need a good descaler or descaling instruction visit
Posted on May 29, 2008
Doesn't make enough steam
This usually happens when the machine needs descaling.Then we have more water than steam.
Mar 30, 2014 | Saeco Aroma Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
The steam coming out of my espresso smells burned
Try descaling amchine to clean boiler.
Mar 12, 2009 | Saeco VIA Venezia
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
May 28, 2008 | Saeco Classico Espresso Machine
Problem with steam wand on my espresso machine
Did you try to prime the wand by running water through it for 4 seconds? After you do that it should work fine.
Aug 28, 2007 | Saeco Classico Espresso Machine
Saeco Classico Espresso Machine Logo
134 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
