Question about D-Link DIR-655 Wireless Router
D-Link DIR 655 - DHCP server but no internet
My wireless router is setup as a DHCP server and distributes IP adresses without a problem. The computers connected however cannot get access to the internet even though i have entered all the internet connection info in the router (Static IP). Has anyone experienced anything like it?
  • 137 Answers
This usually happens when the router has timed out trying to grab an IP address from your modem.
I suggest unplugging your router and modem, waiting 1 minute, plugging in your modem, wait 1 minute, plug in your router, wait 1 minute, then try to connect again.
If this solution has helped you, please take the time to rate me.
Posted on Oct 04, 2009
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
I have bought a d-link dir-655 router. Trying to install it now. I do not have a CD-room.. Trying to enter the router by typing http://192.168.0.1 in the url-window in Firefox (also google crome), but...
You must be on the same network as the Router is your computer only connected to the Router ( with lan cable ) if so what is the IP address on your computer. If you are on the same network as the router the computer should have the IP address 192.168.0.xxx if not check if your computer has DHCP in the properties for the netcard, and change it to DHCP if it is not and then restart your computer and try again. I hope this will work.
Nov 13, 2010 | D-Link Xtreme N DIR-655 Wireless Router
CAN NOT GET INTERNET FROM DIR-655 TO NS7000S
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a DIR 655 D Link router and I can't save changes.
Lots of possibilities, especially if the wireless device and your PC are older - the DIR 655 doesn't support wireless protocols 802.11 a and b, for example, only the newer g and n.
Start with getting the router software up to date (see http://us.dlink.com/products/connect/wireless-n-gigabit-router/ )
using an Ethernet link to a PC, and then debug the wireless access. The DNS message could be caused by the Windows wireless adapter config having a manual IP address vs the router being set for DHCP (dynamic) or vice versa.
Sep 10, 2017 | D-Link DIR-655 Wireless Router
I have two computers, Computer A that is hard wired to a cable modem and Computer B with a D-Link DWA-556 card in it. I also have a D-Link DIR-655 wireless router connected to the cable modem. My problem...
Does folder sharing work through WiFi?
Might be that the IP ranges are not in the same subclass network if the IP numbers are not coming from the same DHCP server.
Did you check the IP number on Computer B in case of the cabled connection and when it is connected on the WiFi? They should only differ in the last digits, not the first 3 groups.
Dec 19, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link 2100 AP is working in Wireless Client mode. It is connected to home network with cat5 cable. The remote ADSL modem is 192.168.1.1 and DHCP on. The first computer in the network obtains IP and...
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Nov 24, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
DIR-655 does not allow Avaya VOIP phone to work
You need to check the DHCP configuration on your router. Also try setting up a static IP on your VOIP phone & try.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DIR-655 Wireless Router Logo
740 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
