Question about Magic Microwave Ovens
How do i set the clock on a magic chef M15E-9PB microwave?
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
  • 958 Answers
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Posted on Feb 11, 2008
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
Posted on Nov 27, 2008
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Posted on Mar 02, 2009
Magic Chef over-the-range microwave oven doesn't cook. Clock, inside lights and turntable are fine
If it lights up, the fuse is fine. On all of the recent Magic Chef's I've repaired, the magnetron has been the cause of the problem you described. Another possible common culprit is the high voltage rectifier.
Aug 04, 2017 | Magic Chef Microwave Ovens
How do I set the clock on a magic chef m15f-9pb microwave oven made in 1990?
perhaps if you can find the manual it tells you how .but on a 25 year old unit our memory fails too
Jun 13, 2015 | Magic Chef Microwave Ovens
How to set up the clock?
No sweat, really easy. press clock button once for 12hr twice for military time, then enter time, press clock button again.
Magic Chef MCD1611ST Instruction Manual Controls Setting The Clock Time...
Mar 31, 2015 | Magic Chef MCD1611ST Stainless Steel...
How to set the clock on a Magic Chef Microwave
Google the model number with "manual" or user manual or visit the Magic Chef site and search there--pretty sure if you call them they can either mail you the same or show you how to get it on their site.
Oct 14, 2012 | Microwave Ovens
I am unable to set my clock on the Magic Chef MCM1110 W/B Microwave Oven I just purchased following the Instruction Manual
Typically all you have to do to set the clock is to press the Clock button, enter the time, and press Clock again. However on some models, clock set is accessed through the main menu, by pressing the Help button and following the prompts.
Aug 17, 2010 | Magic Chef MCD1110ST Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Setting clock
It depends on the brand and model.
Normally it's a sequence like:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
If not, please post a new inquiry with your correct brand and model.
May 23, 2010 | Magic Chef MCD1311ST Microwave Oven
How do I set the clock on my magic chef microwave model dm85k-v1
set the settings!! set the clock and enjoy time!~
Nov 04, 2009 | Magic Microwave Ovens
1992 magic chef (panasonic) microwave. Model M15E-5B. In a RV with very little use. Ran empty. 5 seconds blue flash at top of oven. Panel lights but only time pads work. Seconds, minutes, ect. Fix with new...
Try this site, it has the best advice on almost ANY microwave problem you can have, I know I read something almost identical to your prob. here:
http://www.repairfaq.org/sam/micfaq.htm.
Mar 31, 2009 | Magic Chef CMV1000B Microwave Oven
Resetting clcok on Microwave Oven..
I have a Magic Chef microwave oven, The model # is MCD1311ST.
After I reset the clock when daylight savings time ended, it displays 1:00 PM as 13:00, 2:00 PM as 14:00, etc. How do I get it back on a 12/12 cycle instead?
Warren.
Nov 08, 2008 | Magic Chef Microwave Ovens
Microwave Ovens Logo
104 people viewed this question
Top Magic Microwave Ovens Experts
William Miller
William Miller
Tom Chichester
Are you a Magic Microwave Oven Expert? Answer questions, earn points and help others
