Question about Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera
Can not install memory card.eject lever will not lock down
I got cannon power shot sx130 is it reads memory card error the memory card is not locked but the eject button is not working how to fix this problem. thanks
Try to switch off the Camera and restart it gain. Again, Sometimes, its due to some auto-run software running in the card which prevents that from ejection. You can try to even format the card in the camera itself. That may work also.
As a last resort, check up your camera and get that memory card removed out of your Camera.
Feb 16, 2015 | Canon Powershot SX130IS Black Digital...
My memory card is locked
Remove the memory card - take your finger nail and slide the tiny lever that says "lock" on the side of the memory card to the "unlock" position. Then reinsert the memory card and it will no longer be locked.
Jul 13, 2011 | SanDisk 1GB microSD Memory Card
How do i resolve memory card locked
Take out the memory card from the camera. There should be a write protection switch on it, flip it off and then put it back in. It should work now.
Mar 06, 2011 | Sony Cyber-shot DSC-T90 Digital Camera
How do I undo the "memory card is write protected"?
there is a small lever on the memory card that can be moved to lock position and the other position is obviously unlocked.
Move the lever to the other position and it should work.
Feb 21, 2011 | Nikon Coolpix 3200 Digital Camera
Hi, the flash card card-eject lever spring is broken and wont eject the card. u have to manually push the card in place and pull the card out. the lever stays up until u shut the card slot door.once the...
I have the same problemI think that the reason that the not record the image is that the card slot door is pushing down on the card eject lever and ejecting the card when the door is closedThe only answer I can think of is to shorten the leverdavidh
Feb 18, 2011 | Konica Minolta Dynax 5D / Maxxum 5D Body...
I try to take photos with Canon powershot A530 but it keeps saying memory card locked. What do I do and what does that mean?
Umm, take out the memory card from the camera and there should be this small lever at the side of the card that shifts up and down. Shift it out of the "locked" mode.
Jul 10, 2010 | Canon PowerShot A530 Digital Camera
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Sd card locked
Perhaps it is!
Look on the left side of the SD card and move the lever up to the top Write protect OFF down is on.Sometimes when inserting a card the lever catches and moves slightly off the top posotion and is then read as locked.
Sep 15, 2009 | Sanyo Xacti VPC-S60 Digital Camera
My vivitarN1659 will not reconize a1gb memory card and either states that the memory is full or that the memory is locked
There should be a tiny lever on the side of the memory card. Unlock the card by pushing the lever up. If it still says memory card is full, take out the battery and push the memory card further into the slot. It should not move while it is in the slot. If it "floats" when you close the battery door, it is not down far enough into the slot. Return the battery and close the door.
Oct 05, 2008 | Cameras
Card Eject Button Not Working
I hgave the came camera it does take two pushes to get it to lock down - just a quirk I guess
Jul 30, 2007 | Olympus EVOLT E-300 Digital Camera
Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera Logo
41 people viewed this question
Top Konica Minolta Cameras Experts
ktpierce
Level 1 Expert
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
