Question about Brother MFC 240C All-In-One InkJet Printer
MFC fails to recognize new ink cartridge
"no cartridge" message afer replacing ink cartridge
  • 3 Answers
SOURCE: New Ink Cartridge
Is the toner cartridge an original Brother or is it remanufactured? The toner cartridge for this model is the TN-350, which has a "flag gear" on the left (gear) side. It is a little plastic piece that sticks out on the new cartridges and, after putting the cartridge in for the first time, it rotates out of the way. This is how the printer knows that the cartridge is new. Some remanufacturers either don't put the flag gear in or they forget to turn it back to the original position when they build the cartridge. So that would be the first thing I would look at.
Posted on Jan 18, 2008
Mix-it-up
  • 832 Answers
SOURCE: new ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Posted on Jan 28, 2008
SOURCE: MFC-240 shows no ink cartridge
Same problem here... Figured out something that works fine for me anyway.
I took some black electrical tape and covered the clear plastic area in the front of the cartridge. It's a bit of a delicate procedure. Need a piece of tape about 3/16 of an inch wide and 1/2 inch long to match the contour of the clear plastic so it still fits inside the printer and can be surrounded by the light sensors.
Unfortunately, I think Brother is making too much on the ink cartridges and therefore is trying to make them tamper proof. I t's backfiring on them. Will never buy another Brother.
Posted on Mar 23, 2008
SOURCE: Brother MFC-3360C cyan ink cartridge replace ment
big hammer
Posted on Jul 15, 2008
Hi all,
I had similar problem, i.e. MFC-240 printing was "forbidden" even if one cartridge was out of ink. This did not make sense if I wanted to print black and white but only cyan is out.
I read about taping the sensor bit of the cartridge to (fool the printer). My solution is instead of using tape (which could require some delicate work), I used liquid paper! Just paint over the transparent spot of the cartridge using the small little brush from the liquid paper bottle cap. Wait til it dried and plug the cartridge back in. It worked!
Jim
P.S.: I pulled the power after I finished printing to prevent its auto-wake (every two days or so) head cleaning job which used up internal ink (=expensive). The surprising rattling really annoyed me.
Posted on Dec 03, 2008
My MFC-430W wont recognize color ink cartridges
Faulty Sensors or Cartridges if they are compatible
Sep 14, 2014 | Brother MFC Office Equipment & Supplies
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Hp dj 800 ink supply station not recognize black cartridge
Does it show a Flashing X for the Black?
1 Replace the Ink Cartridge that has failed.
2 If the message continues to appear, clean the electrical contacts
inside the Ink Supply Station (power OFF the Printer first).
3 If the message continues to appear after cleaning the Ink Supply
Station, replace the Ink cartridge again.
Mar 09, 2014 | HP DesignJet 800 Printer
My Brother MFC 440CN will not recognize a Brother
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Jan 23, 2010 | Brother Office Equipment & Supplies
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-210C does not reset after ink is replaced
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and probably other similar printers in the MFC range.
Nov 21, 2008 | Office Equipment & Supplies
Unable to clean message
Remove the ink, turn off the printer. restart the printer then reinstall the ink
Nov 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink cartridges....
Which cart arent recognized? The yellow one or the cyan(blue) one or both?
Anyway:
Unplug machine from power. Wait three minutes. In this time take all carts out and close cover. reconnect machine to power. Machine demands carts. Open cover. Reinsert carts. Make sure that the support clip of the cart.holder is secured above the cart cover.
If you still have probs with one cart. the led contact on the circuit board is defectiv. You need a new cart holder then, which can be ordered as a spare part from a service partner near your home (see brother homepage).
Nov 13, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Nov 08, 2007 | Brother MFC-5840CN All-In-One InkJet...
Mfc brother printer
Sep 13, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
