Question about Gateway LCD17TV 17 in. Television
LCD TV is darker on one side
My 26" LCD TV screen is darker/dimmer on left half. The other side is normal. Is it the backlight problem? I tried to locate the lamps/backlights but couldn't find it. The company which made that TV seems disappeared or out of business. Their phone number is disconnected. I have no way to order parts from them. Where can I get backlight for my TV?
  • Anonymous Feb 11, 2009
    My gateway 17 in tv is dim on one side it seemed to worked the i shut it off dos it need to heat up how do i fix this waht do i need
4 Suggested Answers
  • 10 Answers
SOURCE: Gateway 26" LCD Power Supply
There is a silver lining....
Unless you physically see burned components on the power supply main board, it
is not fried. If you examine the board on the back side ( solder joint side) you will notice that there is a devider that is clearly marked between the Primary and secondary sides of the board. There will also be a large transformer accross this area.
All switch mode power supplies have optical couplers which cosist of a light emmiting diode usually infared and a photo transistor. These are for protecting the secondary side of the board or the expensive side. A typical switchmode power supply for an LCD tv will have at least three of these. They are roughly 1/4 inch long and 2/8 inch wide
and are black with four leads. They will be directly accross the marked portion of the board that seperates the primary or high voltage side of the board from the secondary.
These opticle couplers or switches cost an average of $ 7.00 a piece and are available
from any electronics supplier such as NTE.
I hope this helps. Remember it can all be repaired. Its a matter of if its economically
worth your time.
Posted on Feb 03, 2008
  • 7 Answers
SOURCE: Backlight flashes on and off
When LCD's "turn on" momentarily before going blank again it is an indication that the backlights have worn out. Cold Cathode Floursecent Lamps (CCFL's) have a limited amount of hours which they can be in operation for before the mercury vapor in them breaks down (or leaks out). When that happens the backlights no longer look like a load the inverter (device inside the monitor which turns low voltage into high voltage) is programmed to look for, and long story short, the inverter does not keep the lamps illuminated because of this being a safety setting, if the load no longer looks like what the inverter is looking for, it could be sustaining an open arc which then leads to extremely high temperatures, and a possible fire. The flash you see is the "firing voltage" (I think that is what it is referred to in the industry) which is a very high voltage pulse used to create the arc between cathodes in the CCFL, creating the arc takes a much higher voltage than sustaining the arc, so even if the inverter successfully creates the arc and lights the cathodes, it quickly doesn't look like a proper load and then inverter quickly turns off to prevent damage. Some inverters try repeatedly so that may be the flashing you see.
In essence CCFL's are usually the weakest link in LCD monitors as far as what is most prone to failure, technology has been improving, but if you keep your monitor on all day long at full brightness, never shutting it down, don't expect more than 3 years out of it :( Some brilliant LCD manufacturers recognize this problem and even make the backlights replaceable!! What a novel concept!!! But due to price gouging, the replacement backlights are usually sold for a premium from resellers, better option than the majority of LCD displays which have the backlights so integrated that you end up destroying the LCD and introducing contaminates in the process of "reviving" the display...
Replacing the cathodes on a 24" display is impractical due to the sheer amount of them, if the panel is not edge lit, there are usually around 16+ cathodes behind the screen, and some are unique to the LCD panel and weird shapes, like U's!
If you still have it, I would definitely be interested in it as parts, but looking at the date of this post I'm sure you trashed it at this point :(
Posted on Jul 25, 2009
  • 8457 Answers
SOURCE: Gateway TV Broken LCD 26"
Tries ur Gateway company or where u bought it,still in waranty u could get cheaper for a replacement.Tries or
Posted on Aug 16, 2009
How can I fix my visio tv 49 inch?
The backlights are out on one side.
Jun 15, 2017 | Televison & Video
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
Samsung LCD 46 inch half of the screen is darker than the other half.
Hi, while fixing another persons lcd tv i used lower rated power supply to try to fire up the tv ( picture-no sound) the bulbs ( actually cold cathode fluorescent ) lit up but only halfway. So sounds like the power supply for your backlight has gotten weak. You may try a workaround I've used on personal equipment, try turning down brightness on tv-this may,if your lucky, even out the brightness. hope this helped. Prodzilla
Mar 30, 2011 | Samsung LN46A650 46 in. LCD HDTV
42 inch samsung lcd tv darker on one side
Its one of two things, bad lamps in the panel or bad Tcon board
Dec 24, 2017 | Televison & Video
Screen Half darker
It sounds like your backlight isn't working properly. LCD screens have backlights that illuminate the colors produced upon their surfaces, so that you can easily see the screen without an external light source. In your case, it sounds like your backlights either aren't cailbrated, are damaged, or were produced unevenly.
There is most likely not a fix for this, though most all LCD screens have some form of light distortion. My own LCD screen is slightly brighter around the edges, where the backlights are located, but this is only noticeable when displaying a completely black screen.
Jun 22, 2009 | LG 22" FLATRON LCD Monitor
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Apr 15, 2009 | Dell Inspiron 1521 Laptop
Top half of screen is darker than bottom half
The problem is most likley the TV backlight - it is very unlikley to be the graphics card or video input or any other circuitry within the TV.
Also, the problem can be manifested by flashing or flickering of one or both halves of the screen, and sometimes it is a left/right split rather than a top/bottom split, depending on where the lights are positioned. Before failure, you sometimes hear a very high frequency buzz for a few weeks before it fails - the frequency can't be heard by most adults as it ranges from 15kHz-25kHz, but children\animals can usually hear it.
Generally you will need to replace the backlight tube or the invertor that drives it. Generally you can identify the backlights as thin glass tubes buried deep within the panel itself usually with one wire going to each end of them - they are very fragile. The invertor is connected to the backlight tube and looks like a circuit board, often containing a high voltage warning. Usually there are two or four conductors connecting the invertor to the tubes, which can be identified as thicker individual wires as opposed to the flat ribbon wire used for data for the actual image displayed on the screen.
On some screens you may be able to unplug\swap one or both tubes to identify if it's the tube or inverter.
Oct 05, 2008 | Televison & Video
One half of screen sees darker than other
Problems described are related to Backlight.It is possible that backlights of affected area have become weak.
You may need to contact the company for repairs and Yes the Repairs may not be cheap.
Nov 01, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Gateway LCD17TV 17 in. Television Logo
443 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
