Question about Kenmore Washing Machines
My kenmore washing machine allows water in but does not agitate or spin or drain. my guess is it is the motor, but could it be a bad capacitor?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the following PDF Whirlpool installation and maintenance manual on top load direct drive washers. It has a troubleshooting section as well as testing procedures for many components.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd try setting the timer to a spin mode and see if the motor works, Also try it in different wash modes, permanent press, short wash etc.
It does sounds (if the motor isn't getting power, and you cannot hear the motor at all) as if the motor or capacitor is the problem.
If you can hear the motor trying to turn, I'd check the motor coupler which transmits power from the motor to the transmission.
See the following for how to pull the cabinet on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Posted on Oct 04, 2009
Kenmore washing machine series 90, will not agitate, spin, or drain. Door switch is good. Wigwag solenoids have continuity. Motor start capacitor good. Motor will spin if belt removed.
Unplug the unit. Remove the hoses on the water pump to check if it is clogged. Water will come out so be prepared. Check how you can check for error codes.
Dec 13, 2016 | Kenmore Washing Machines
Kenmore direct drive washer hums, no agitation.or spin or drain
possibly a timer fault if everything down below checks out. does the machine have a capacitor? check that first.
Nov 10, 2013 | Kenmore Washing Machines
THE WATER WILL NOT DRAIN, AND THE SPIN CYCLE WILL NOT WORK
Your machine is whats called a direct drive. Meaning that the motor is attached to the transmission and other part directly. Your motor turns in one direction to agitate and in the other direction to pump the water out and to spin. If you unit is not pumping or spinning, your motor is not running in that direction. I would check the the water pump and make sure it will turn. If not, it has something inside binding it. If it does turn, you have a bad motor. If I had to guess, you have a bad motor. This is not common with these machines but they do go out.
Oct 13, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
Jan 28, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
