Question about TechSmith CAMTASIA STU V1.0 5-9U for PC
Camtasia movie will not play fully
Hi
I am trying to watch a series of camtasia videos.Each time I click on link and the Camtasia movie starts to load BUT will not completely load - so i dont get the full movie content each time ;-(
Any ideas would be great
Happy Holidays ;-)
  • Anonymous Jun 25, 2008
    I only get audio when I try to play a Camtasia-produced avi file with both WMP and Quicktime. These are the only 2 players available on this machine. What can I do to fix this?
  • Anonymous Mar 18, 2014
    I had to reformat and reload my PC. I then installed the Camtasia 7 that I purchased a couple years ago and then installed the Camtasia 8 that I recently got.
    However, when I try to run Camtasia Recorder 8 either from the taskbar icon or from the program files, nothing happens.
    I checked the processes and there is no reference to camtasia there either.
    I am running Windows 7 Pro with 8 GB Ram and a Quad Core processor.
    What can I do to get this to work?
    Thanks in advance
    Larry
Need a product key for camtasia studio 8.0
You can download a free trial here, and if you like it, you can buy the code here too.
Capture Edit amp Share your ideas with the world using Camtasia Studio
Jun 04, 2014 | Computers & Internet
Camasia 8 Recorder won't work on Windows 7
Delete 7 and 8 but then only reinstall 8 and see if that works because they might be screwing with each other.
Mar 18, 2014 | TechSmith Camtasia Studio for PC
Hi, I am having Windows 8 laptop, 1st time I connected logitech plug n play headphone, they worked fine , were even set as default device for Skype, but when I restarted my system nothing is happening....
I set the headset to be the default audio device for the computer. I can use Skype fine and can hear iHeart Radio. However, I can't hear my Camtasia recording and don't even know if the microphone is working with it. I also can't hear the Camtasia tutorials or videos on YouTube.
Does anyone have any ideas? I'm using the trial version and want to make sure I can use the program before I buy it. by Video Recording Mobiles Video Recording Mobiles Tablets
Oct 19, 2017 | Logitech 250 Headset
Camtasia Studio 8 Only Opens Once per Start-up
what u need to do is if you have windows press ctrl shift esc and the task manager should pop up go to processes then on the list you would see Camtasia studio right click and select end process or if u see the name more than once end the process of them all the reason you have to do this is because for some reason the first time you open and close it it dos not actually completely close witch then gets in a glitchy state to where you can not open in again but by ending the process u should be able to open it again
Jun 17, 2013 | TechSmith Camtasia Studio for PC
Broadcast yourself
you first need to register!
Second subject is to make a video:
you may download Camtasia Studio Trial.
In my opinion it is the best way to make videos - record your screen/import pictures, videos/many other things.
If you need a tutorial on how to use Camtasia Studio, click here.
If you have any other questions/need help, just ask!
May 19, 2013 | YouTube Videos
You tube videodownloads
If you're trying to download videos you might want to try this program. I have it my self. It's called Camtasia
http://www.techsmith.com/camtasia.asp
Sep 23, 2010 | YouTube Videos
Extremely slow to update changes on timeline...
This is a known issue when too many edits are made. Supposedly Camtasia Studio 6 (recently released) will decrease your editing time by 30%. I have not been able to verify this yet. The best way to resolve the issue is produce what you have as an AVI and start editing that, and so on, and so on.
Oct 02, 2008 | TechSmith Camtasia Studio for PC
Memory Problems
The clip can be recovered if you open the temporary directory where Camtasia stores the raw captures in AVI format. The path to the temporary directory can be found by opening the Camtasia Recorder > Tools > Options > Program > Temporary file folder (I'm using v.5 so it may be a little different in other versions).
I've found that there's a certain workflow that seems to work best and you can avoid accidentally erasing your temporary files and having to start your capture session over from the beginning...
  1. Stop Camtasia Recorder - Pressing the Stop button on the Recorder likely won't work, so open the Task Manager (CTRL+ALT+DELETE) and select "CamRecorder.exe" from the Processes tab and click "End Process". Don't open Camtasia Studio right away after doing this step - You'll likely be prompted to recover the recording and in my experience Camtasia hasn't done a very good job at being able to do this successfully and you may end up losing your temp files.
  2. Recover your raw capture files - Navigate to the path where Camtasia stores its Temp files (look above for instructions). Typically, there will be a folder titled "CamCapture{random string of numbers/letters}" - look for a folder with a date modified attribute of the date/time you were working on your project. In that folder, there will likely be several audio and video files as well as an XML data file. The video files will all be 1GB apiece as Camtasia splits the capture into chunks and then pieces them back together to create one continuous file. Cut and paste the files from this folder into a new location outside of the Temp directory. The most important one is the FileWriter{random string}.avi as this is the pieced together file - It will have the largest file size.
  3. Add your media files to the clip bin/timeline - Start a new Camtasia project and import the FileWriter{xxx}.avi clip into the Clip Bin and drag it onto the timeline. Now all of your video/audio should be recovered and available for you to edit. If you have particularly long clips, you may want to check how the audio syncs with the the video towards the end of the clip. If it's messed up at all, you may want to try adding the smaller, chunked recording segments sequentially onto the timeline to see if that helps. If the FileWrite{xxx}.avi clip is good though, you can delete all of the other smaller audio and video clips associated with the capture from your pc to save space - just keep the FileWriter{xxx}.avi clip - the XML can be deleted too.
Good luck - We've had the same trouble here and we use Camtasia almost everyday. In my experience, this seems to happen more frequently when we capture larger dimensions - especially if the capture contains full motion video (as opposed to just screen captures of a product demo or something) and we always seem to have trouble when capturing things that play back FLV or SWF clips at a higher bitrate. This issue is also described in TechSmith's Camtasia knowledge base.
Apr 22, 2008 | TechSmith CAMTASIA STU V1.0 5-9U for PC
Uploading Camtasia video to web page
If you are using a Flash then you can create your own flash play, pause, stop and exit button by flash using action script so that when you upload video through website it will work. if no idea with action script then refer to this site www.actionscript.org .... Thank you
Apr 11, 2007 | TechSmith Camtasia Studio for PC
Transitions
You should export your two video clips and make a transition in Windows Movie Maker. This is much faster and you have a wider selection of transitions.
Aug 09, 2006 | TechSmith Camtasia Studio for PC
TechSmith CAMTASIA STU V1.0 5-9U for PC Logo
380 people viewed this question
Top TechSmith Computers & Internet Experts
David Payne
David Payne
Are you a TechSmith Computer and Internet Expert? Answer questions, earn points and help others
