Question about MSI K9N4 SLI-F Motherboard
3 beep memory error
Hi, i have just purchased ans installed the above, with 4 x 1gb memory sticks fitted, and I am getting a 3 beep memory error code. I have tried each stick individually, and they all work. I have ensured that the bios is set to the correct 667mhz clock speed, and that when all 4 are installed they are seated correctly in the board. Any obviouse problems / solutions, or does the MB sound fault, in which case I will return it.
Cheers
Paul
  • 31 Answers
Try checking you RAM by setting the option in BIOS Quick Boot to Disable. It will analyse your system's whole memory which will help you to conclude the faulty item.
Posted on Dec 22, 2007
    Scholar:
  • 103 Answers
Yep, I think you probably have a faulty MB. If all the memory modules work individually, then the fault is probably one of the RAM slots.
Trying to fit new 1gb memory stick in dell optiplex sx 270 but the system will not acccept it and not boot up error codes of ab yellow but cd green all it does is beep when fitted yet i refit the 256mb...
Hello.
Memory is not interchangeable. Depends on your system, as to what memory to use. An error is telling you the memory is not correct for that PC.
Your Dell Optiplex sx 270 uses DDR PC2700 and DDR PC3200 memory.
Hope this helps.
Dec 20, 2009 | Dell OptiPlex SX270 PC Desktop
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
4 short beeps on vostro 200 monitor shows black?
http://support.dell.com/support/edocs/systems/vos200/en/index.htm
the above link will allow you to download pdf versions or view HTML versions of the Dell manuals for your machine.
4 beeps is RAM read/write failure
if you recently installed new RAM (memory) you should check to be sure that it is compatible. If not, you might just have a loose memory stick.
just remove and re-install memory modules making certain to seat them firmly.
!!!! Very important ..before touching memory.. be sure to discharge any static from your body - by touching anything grounded (I usually leave my tower plugged into a grounded outlet and make sure the rocker switch to the for the power supply(the switch on the back of the computer) is turned off.
Aug 09, 2009 | Dell Vostro 200 PC Desktop
Hi, i have an acer aspire 1640z i upgrade my bios from 3a18 to 3a24. after installing my notebook restart and i hear 3 beeps ( 1 long, 2 short) and my lcd doesn't turn on the motherbord work fine. Please...
1 long, 2 short beeps indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
Re-insert the memory into the same slot.
  1. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  2. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
The RAM is located under the laptop behind a hidden panel.
Good luck and let me know how you get on and if you need any more help or advice.
Jul 20, 2009 | Computers & Internet
Dell 5150 Start-Up Problem.. beeps
Beeping on startup is a memory error. The blue screen you got was most likely caused by a memory error as well. First, take out then re-install your memory. If the error persists and you have more than one stick, test each one singly to find out which stick is bad.
Jun 27, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
See http://www.computerhope.com/beep.htm.
You must count the beeps.
Mar 17, 2009 | Foxconn 6100K8MA-RS Motherboard
"my computer will only beep no screen,it beeps
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Mar 14, 2009 | Dell Dimension 8200 PC Desktop
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
MSI K9N4 SLI-F Motherboard Logo
112 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
