Question about Samsung SCH-a870 Cellular Phone
Stuck on silent mode and cannot get the ringer to ring
My phone only vibrates and will not ring. the silent mode is on and i cannot turn it off. how do i get the ringer to ring again?
  • 3 more comments
  • Anonymous Jan 07, 2008
    TURNED UP THE VOLUME ON THE SIDE
    GONE TO TOOLS, VOLUME
  • Elizabeth Huntley Mar 08, 2008
    How to turn the ringer back on.
  • Anonymous Apr 19, 2008
    Me, too. Have you figured it out yet? I've tried everything.
  • mariebee May 05, 2008
    Stuck on silent mode and cannot get the ringer to activate... I need a solution .
  • Anonymous Mar 27, 2014
    How do I get Silent Mode to turn OFF so I can hear rings?
All you have to do is hold the pound (#) button down. It will then say exit silent mode. If you ever want to put your phone back in silent mode, just hold the pound (#) button down.
Posted on May 03, 2008
Rings
Posted on Dec 22, 2007
SOURCE:
Why is my phone on silent ?
Has happened before at many of our locations, always after being dropped. Usually the phone is not on silent, the ringer is broken. The only solution we have found is top replace the handset.
Aug 22, 2014 | EnGenius DURAFON1X DuraFon 1X System Phone
IPad won't ring when calling face time
either your profile is silent or your volume is down. whenever your profile is in silent mode/vibrate mode even if someone is calling you it wont ring. change that to ringer via settings and sounds.
Aug 27, 2013 | Cell Phones
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I have a nokia 6275 cell phone but he can't do vibrate in any mode
Go to profiles, select a profile you wish to use, click on personalise. For the vibrate option, you can select 'vibrate, then ring', if you want it to vibrate before it rings.
Select 'rythm', if you want it to be vibrating as it rings .
If you need a profile where it only vibrates without sound, most prefarably in the silent mode, select that profile, choose the personalise option. It the ringer option, select none. In the vibrate option, select vibrate only.
Pls if this was helpful, rate it a thumbs up.
Mar 23, 2011 | Cell Phones
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
My LG VX-8700 does not vibrate. Ring works, but vibrate mode is the same as silent mode. Can this be fixed?
Yes,
What happened is you probably set it on silent and from the soft keys, you increased the ringer volume. What you want to do is go to main menu => settings => profiles, and from there make sure your ringing volume is set on lowest possible.
Oct 28, 2009 | LG VX-8700 Cellular Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Ringer
go into profile and set ur message setting 2 silent and ur ringing tone 2 set anytone./.it wont make noise. reply me
Jun 05, 2008 | Samsung C417 Cellular Phone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Samsung SCH-a870 Cellular Phone Logo
1,633 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
