Question about Panasonic NIA56NR NI-A56NR Iron
Panasonic NIA56NR NI-A56NR Iron shut off and wont turn back on
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Replace cord
yes you can change it or you can also take some repair.
Jan 19, 2014 | Panasonic NIA56NR NI-A56NR Iron
Not heating what will be the problem
if it is not heating up -- the problem could be a few things,, it could be a bad cord / connection ( at the iron side or at the plug side ),, it could be a bad switch ,, or it could be a burned out heating element. if you have a volt meter ( or know someone that does ) - you can do a few test to the wiring and see what the trouble is.
if you need further help -- please feel free to write me back here and I will walk you through the steps the best way that I can. but if you do not have a volt meter - then just drop it off at your local small appliance repair shop and for a small price I am sure they can fix it quickly -- if it is just a loose wire or bad plug - the cost will be about 10 to 15 dollars ( depending on where you live ).
c...
Feb 23, 2011 | Panasonic NIA56NR NI-A56NR Iron
It not turn on.
If u could open the internal part and check the THERMOSTAT and the THERMAL.
That usually the problem w/ FLAT iRONS!
Might as well check ur power cord too, it might have some internal cut wires in it, use ur multi tester to test the current continuty!
If u don't know how to OPEN it, u might as well, bring that to the nearest service center!
Nov 08, 2010 | Panasonic NIA56NR NI-A56NR Iron
Panasonic Iron won't heat
most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Apr 24, 2009 | Panasonic NIA56NR NI-A56NR Iron
Panasonic iron NI-A56NR wont turn on
first test your heating element to see if it is working.
You can by pass the control module by removing it from the line. Just disconnect all wires that goes to the module and put aside, then, connect back lead to the far right connection and white wire to the third connection from the left. Be careful playing with electricity is hazardous to yout health if you don't know what you are doing.
Jan 17, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Iron is out of order
an appliance repair center could probably fix it but you have to consider the cost against a new iron
mostly it is more costly to repair than to fix
Oct 19, 2017 | Panasonic NI-A57SR Iron with Auto Shut-off
Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
Dec 13, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
NIA56NR Iron = Panasonic
the filament is gone
u need to replace it from local vendor
Mar 14, 2008 | Panasonic NIA56NR NI-A56NR Iron
My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Aug 11, 2007 | Panasonic NI-R73NR Iron
Panasonic NIA56NR NI-A56NR Iron Logo
299 people viewed this question
Top Panasonic Irons Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
Bill Boyd
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
