Question about Kenmore Dishwashers
Our kenmore dishwsher somehow got "locked" and that light keeps flashing. I cannot get the lock to come off even by doing what the instructions say. Can you help me reset this? Thank you.
  • vanyo Oct 04, 2009
    Holding the no heat dry button longer did not take care of it. I will try these others and see what happens. Thank you.
    It has not worked yet. I need to follow the additional steps, which takes over an hour to do. I am not sure if it will work.
  • 2,200 Answers
The usual way to cancel this on a Kenmore machine is to press and hold the "No heat dry" button for longer than 4 seconds. This should cancel the lock and resume normal function. I recommend you hold this button in for at least 10 seconds.
If this fails - leave the door ajar for one hour then try the procedure again.
If the problem persists disconnect the mains power supply at the breaker for 30 minutes - then reconnect to see if the issue is resolved. If the machine continues to show lock it is probable that the control panel or key pad is at fault and will require service attention.
One final thing you can try in this situation prior to calling a tech is;
1) Disconnect the mains supply.
2) Remove the control panel from the machine. (6 screws)
3) Disconnect and then reconnect the ribbon cable that attaches to the control panel.
4) Replace control panel and power up to see if issue is resolved.
If you look behind the kick panel you should find a tech sheet that describes how to perform a diagnostic test to determine if your key pad is bad or your control panel is bad if the problem is still there after you have tried all of these.
Hope this helps. Please do rate this answer. Thanks.
Posted on Oct 04, 2009
I have a ge profile oven model starts pt 916 when i broil food the "locked" light flashes, i usually keep the oven door open so i can watch the food after about 5 min the locked light goes off
The only thing spring to mind Mary is that you somehow selected a cleaning cycle which superheats the oven and turns burnt on fat and grease to charcoal. The cleaning cycle never finished and the stove remembers it. The light is flashing to remind you. When the cleaning cycle is in progress, the door locks until it is finished.
Either remove the wall power plug or flip the breaker and leave it overnight. It _should_ erase it from the memory. Or you have to compete the cleaning cycle as per the instruction book.
Sep 05, 2016 | GE Ovens
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
"Lock-on" light flashing
heated dry and normal toggle untill all lights light up then turn unit off. try that
Jan 02, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore dishwasher LOCK ON light will not stop flashing
is that the button closest to that lock light? if not it may be a button closer to the lock light. if it still doenst work you may have a short
Nov 21, 2008 | Dishwashers
Dishwasher electronic panel locked
remove the touch panel and unplug it for couple of minutes. it should reset>
Aug 20, 2007 | Kenmore 15899 Built-in Dishwasher
Dishwashers Logo
22 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
