MY AC IS GIVING BAD SMELL WHEN I ON IT - Heating & Cooling
  • 614 Answers
Is this a burning smell. AC units sometimes have what they call dirty sock syndrome. The evap. coil has bacteria that puts of an odor. You have to have the coil chemically cleaned and sanitized to get rid of the odor. Rus
Posted on Oct 04, 2009
Bad smell coming from ac on 2005 grand Cherokee
Why Does My Air Conditioner Smell Bad? - Hydes AC
www.hydesac.com/air-conditioner-smell-bad/
Apr 15, 2015 - Does your house seem to develop a strange smell every time that yourair conditioner ... Possible reasons why your air conditioner smells bad.
Sep 30, 2015 | AC Cars & Trucks
Weird Car Air Conditioner Smell: What It Means and How to ...
www.carsdirect.com > Car Maintenance > Interior Car Maintenance
This causes an unpleasant odor coming out the air conditioner unit. Also ... This can result in a bad smell every time you turn on your air conditioner. You can ..
Truck is giving off a rotten egg smell !
rotting egg smell is associated with your cat converter going bad
Jun 24, 2013 | 2004 Cadillac SRX
I have a 99 Chrysler 300m when I turn the heat r ac smoke comes from the vents and from under the hood.. When I turn the heat/ac off it stops.. It has a smell like burning rubber
sound like AC COMPRESSOR clutch bearing going bad causing locking up putting drag on drive causing drive belt slip giving a burn rubber smell.
Jun 17, 2013 | Cars & Trucks
98 silverado ac blower only blows on high after it froze up after ice storm /motor or switch bad?
Sounds like the resistor pack on the heater case needs replacing. That's how you get lower motor speeds. Unplug it, remove it, and look for broken wires on the little pack. Some water or ice probably got around it and ruined it, giving you that smell of burning wires. Ice and water must have come through outside air recirculation passage.
Dec 05, 2011 | Cars & Trucks
I have a ESP412J-L window unit purchased last summer. After putting the window unit in for this season the ac started off giving cool air up to about a week ago, now it does not give off the cool...
Hello, if you have cleaned the unit, checked the filter , cleaned the coils then either the unit is low on refrigerant due to a leak or the compressor is not engaging due to a bad thermostat on the unit, bad capacitor, or the compressor itself is shot. If its under warranty i would take the unit back to the store and getna replacement.
Jun 12, 2011 | Haier ESA312 Energy Star Window Type Air...
After i put the ac on my bmw x5 2003 get over heat and smell burn
pls. check your ac compressor magnetic clutch attached in front of ur compressor if its working/ ac clutch engage when u turn the ac switch on and disengage when u turn the ac switch off/ it normally makes a clacking sound when it engage with the rotation of ur compressor/ if its not engaging it means ur magnetic clutch is stuck up giving excessive load to ur engine thats why it overheats/ it smell burnt because its magnetic coil is fried/ or check cooling system of ur car might be that coolant is empty/ fan is not working/ radiator is clogged or thermostatic valve is stuck blocking coolant flow....
Apr 09, 2010 | 2003 BMW 5 Series
Have a AS18U samsung spilt AC which is giving out very bad odour..
just happened out of the blue or first time starting it this year
May 12, 2009 | Heating & Cooling
AC does not cool. Compressor kicks on and off (Humms when trying to start, electrical smell)
There are a couple possibilities:
1. If this is the first time you've started them for the season, one of the compressors might be seized up from sitting over the winter. In which case, new compressor required.
2. If you've just had the compressor serviced including recharging the system, it's possible that the system is simply overcharged. This will stop the compressor from working and giving you the same symptoms as above. If this is the case, you should have the service people come back with some guages and recover some of the refrigerant and the compressor should be fine.
3. If the unit has been sitting and there is a slow leak then there is not enough pressure in the system to allow it to run. The compressor will shut down if there is not enough pressure, but since you say there is a smell, i really doubt this is the case.
Most likely it's #1 or #2 above. If you haven't had it serviced recently, then yeah, it sounds like you're in need of a new compressor.
Good luck.
Apr 16, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
863 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
