Question about Dell Vostro 1510 Laptop
When I turn computer on the windows boot manager screen comes up. It says windows is having problems communicating with a device on the computer. It says this error could be caused by a removable storage device such as an external USB drive while the device is in use or faulty hardware such as hard drive or CD ROM that is failing. Gives me the options to hit enter and continue or ESC=Exit. Either one sort of restarts and it does the same thing again. I can press F2 or F12 at one point in the process which takes me the boot menu, but that's it It was working fine last night and when I got up this morning the screen was blank and nothing worked. Tried ctrl alt delete, nothing worked so I had to shut it down by holding power button
  • 63 Answers
Sometimes when you use ram sticks on some older computers they do not handle taking teh ram stick out of the USB port without first closing out teh device OR if you have the RAM stick in while you are booting the machine... it will select the ram stick as the boot device and appear there is no oprerating system present.
In you case when you go to the boot menu.. be sure the boot menu is set to select the hard drive as the primary boot device. If it is not then you can make the change at teh bott up screen.
Posted on Oct 04, 2009
I have an hp dm3-1130us laptop with Win 7. I haven't had problems with it until today. I have it set to sleep when I close the screen which I did, but when I opened it and it turned back on it only...
http://www.hp.com/ctg/Manual/c01893277.pdf
See chapter 5, Also read the part about setting or disabling the processor sleep mode, Disable it. IF it boots normally
Go to Start. In the search box type "Device Manager" (without the quotes) - and then press Enter; this will open up the Device Manager. Double click on 'Universal Serial Bus controllers.' Now you will see a list of 'USB Root Hub'. Right-click the top one of these and select 'Properties'. Click on the Power Management tab, un-tick where it says 'Allow the computer to turn off this device to save power' and click 'OK'. Now repeat this action on the other 'USB Root Hub' items in the list. when they are all done you can close the Device Manager, and your USB mouse and keyboard will now be able to re-awake your computer
Mar 17, 2017 | Computers & Internet
Hello, Im having a problem with my Dell INSPIRON 1750.
it's possible your hard drive has gone bad, that's what it sounds like
Aug 02, 2012 | Dell Inspiron Computers & Internet
Haveing problems with hp notebook 1100 boot mgr missing error while initializing NIC
Hi There,
I'm having trouble understanding what you mean by this - are you attempting to boot from LAN? Are you able to boot into windows at all?
What it sounds like is that your computer is either missing a boot manager, or you've assigned (in the bios) LAN boot as the priority boot device.
If that's the case, you can change the boot device priority back to internal hard disk in your BIOS (pressing F2 or F10 at startup splash screen)
If you're missing a boot manager for a windows installation, you can insert your windows installation disk and select "repair an existing installation" to repair your boot manager
Jun 06, 2012 | HP Computers & Internet
Windows boot manager page with status 0xc00000e9
If you don'yt have a Vista DVD,you can borrow any for startup vista repair. This is very common and HP/Compaq don't usually give operating systen vista dvd
Oct 02, 2009 | HP Compaq Presario V6000T Notebook
Windows boot manager-hardware failure
Try pressing F-8 and look for last known good working configuration.
If you are trying to reload from CD/DVD drive and it continues to boot into your old windows configuration, Enter your BIOS settings, and change the boot order to CD/DVD and then Hard drive
Sep 15, 2009 | Acer Aspire 5520-5579 Notebook
Hit F8 a few times while your computer starts to boot, a boot selection screen should come up. Try selecting "Last Known Good Configuration" and see if you can boot up without running the repair install.
Sep 02, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Need a system recovery? Tried the F8 method--doesn't work! Help!
Just unplug the hard drive cable and plug it again. otherwise if problematic replace the cable.
Apr 24, 2009 | Gateway GT5404 PC Desktop
Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
Mar 25, 2009 | Canon CanoScan 4400f MultiFunction Color...
Won't scan or copy
Solution
These errors are usually caused by a failed scan, a bad installation, communication problems or software conflicts. Follow the steps below until the problem is corrected.
Step one: Restart the computer
Close all programs and restart the computer. A required task might have stopped running or the system resources might have decreased due to tasks left running. Restarting the computer will refresh all Windows tasks as well as increase the available system resources.
Step two: Check for the correct entries in the Device Manager
Verify that the unit was installed on a DOT4 virtual port in the Device Manager.
  1. Right-click My Computer , and then click Properties .
  2. Click the Device Manager tab. (In Windows 2000 and XP, click the Hardware tab , and then click Device Manager .)
Check the list of installed devices for references to DOT4. If there are no DOT4 references, the software has not installed correctly.
If any of these entries are missing, the software did not install properly. Review the information in the HP document Troubleshooting Installation Issues for USB-Connected HP All-in-One Products in Microsoft(R) Windows (bpu01858) for installation assistance.
Step three: Check for communication problems between the all-in-one and the computer
Communication might have failed between the all-in-one and the computer. Review the information in the HP document USB Connected HP All-in-One's Software Reports a Disconnected or an Error Status (bpu01859) to check for communications problems between the HP all-in-one and the computer.
Step four: Check the computer to see if it is infected with a computer virus
If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. The following are symptoms a virus problem:
  • The scanning software works after installing the all-in-one software until the first time the computer is restarted.
  • In the Device Manager, opening the Properties of the Imaging Device entry will reveal a status of "code 19" or "code 28".
  • A Scanner Cannot be initialized error occurs. While this error may other reasons, a virus will cause this error.
When the all-in-one is turned on and connected, follow the steps below to see if this is the problem:
  1. Right-click My Computer (click Start first in Windows XP) and then click Properties .
  2. Open the Device Manager:
    • Windows 98 and Me: Select the Device Manager tab.
    • Windows 2000 and XP: Select the Hardware tab, and then click Device Manager .
  3. Locate the Imaging Device entry and click the plus (+) beside it. It may have an exclamation mark beside it.
  4. Right-click the all-in-one entry under Imaging Devices, and then click Properties .
  5. A Properties screen will open. Look at the Device status section.
Hope it may helps;.
Regards, VOTIT
Sep 20, 2008 | HP Photosmart C4180 All-In-One InkJet...
Dell Vostro 1510 Laptop Logo
210 people viewed this question
Alun Cox
