Question about HP Computers & Internet
My fan runs too often - HP Computers & Internet
  • 3,153 Answers
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Posted on Oct 04, 2009
Testimonial: "thanks guy's very helpful"
  • 63 Answers
This atypicall indicates that the air flow has been inhibited. Open the case and check for dust and vacuum out all dust balls. check to be sure that if you have air flow cowls over teh processor you remove them and vacuum here also.
If air flow is not teh problem then you have issues on teh motherboard that will require a bench technician to diagnose.
2002 mitsubishi galant are fans supposed to run when starting car?
The fans should run whenever the AC is on. But if it's off, the fan should only run when the computer thinks the temp is too high
Jan 04, 2018 | Mitsubishi Cars & Trucks
My coolin fan wont come on wat should I do
Cooling fan is controlled by a relay and a temp sensor. You need to check that each piece is working.
Run power to the fan. fan run? fan ok.
Bridge the relay. Fan run? run power to the relay coil. Fan run? relay good.
find temp sensor. replace.
May 29, 2015 | Cars & Trucks
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
I have a 2005 Jetta 2.5 and it seems like one fan runs to fast
One fan should run when engine is running. Other fan should run when AC is on.
Jun 28, 2009 | 2005 Volkswagen Jetta
My condensor fan is not running. I looked in the
Hi, Check voltage to the fan. The fan will only run when the compressor is running. If you have voltage to the fan whilr the compressor is running, replace the fan.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 14, 2009 | Frigidaire FRS26R4A Side by Side...
03 Mini Cooper Power Steering Fan will not run
2006 mini cooper s power steering fan seezed. replaced with new fan won't run?
Mar 30, 2009 | 2006 Mini Cooper
Cooliant fan not running
The tempature switch for the fan will be located on the radiator tank, most likly near the bottom or mid way up. It will have two wires in most cases.
With the key on but the car not running, connect these two wires together. If the fan runs, replace this radiator switch.
If the fan does not run, pull the connectors apart going to the fan itself. Jump power and ground to each of these two wires. If the fan does not run, the problem is the fan. If it does run, the problem is most likely the relay for this fan
Good Luck!
Feb 09, 2009 | 2001 Kia Rio
2001 Jeep Grand Cherokee Radiator Fan Doesn't run
Have you confirmed the fan has a good ground, sounds like you have eliminated the issue of 12 volts, when you turn on the fan then the AC does the compressor run? if the compressor runs pull the plug to the fan motor and check to see if has 12 volts with a test light, wait for moment because the fan may not run until the AC system pressure reaches a certain pressure point, this means that even though the compressor is running the fan may not always run, There is a quick test for the fan circuit, disconnect the fan sensor at the thermostat housing, the fan should come on, this is failure mode, so if the switch goes open the fan will run to keep the engine from overheating , let me know after the tests are run.
Dec 01, 2008 | 2003 Jeep Grand Cherokee
Computers & Internet Logo
1,014 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
