Water going into machine slow, water coming from
Water going into machine drum slow, water coming from hose is ok. need lift washer top, how?
  • 909 Answers
There will be either 2 or 3 screws on the rear of the lid,remove and slide the lid backwards, lifting slightly on some models.
Posted on Oct 04, 2009
Machine wont agitate
Could be several things, is the machine filling up with water?
1st thing is the water level switch, inside at the rear of the machine, If water is not detected then the machine won't start.
This is probably the cheapest and easiest to replace first.
Isolate the machine from the mains, lift the whole top lid (insert a flat blade 4" from each side at the front top seam to release).
Lid will tilt all the way up and back.
Switch is rounded about 3" diameter at the back behind the drum, 3 wires with a small hose attached, replace keeping all the wires in the correct places and re-attach the hose.
Does the machine spin - motor OK
Nov 29, 2010 | Admiral AW22 Top Load Washer
Water leaking when machine is off
you need a new water valve. it is located at the back left hand side under the main top(the piece the hot and cold water hoses hook on to)
Feb 08, 2010 | Whirlpool GHW9300 Duet Washer
Drum seems out of balance does not allow water to drain because water pump hose kinks
Hi, you will have to open machine, and check spring, maybe one of your spring are broken, or strain, first lift top, and remove sides of machine, put hands on tub and rock complete assemble back until tub centers, if tub is tilted left, spring on opposite side, is loose or broken, if broken, replace, but most time they slip out, this is cause, if machine are overloaded, or not level properly, when washers are not properly leveled, when they reach spin cycle, they could go outside and come back in, just making a point, check you machine level before you start. good luck.
Aug 07, 2009 | Maytag PAV3240A Top Load Washer
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Apr 19, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
Apr 14, 2009 | Admiral AW22 Top Load Washer
Water fills drum, everything still works
The cold water valve is probably stuck open. It should open only when there is voltage across the valve. It could just be clogged inside. If you can remove it, you might be able to take it apart and clean it. Just make a note of how parts fit together as you are taking it apart. Clean all parts with old toothbrush and reassemble. Before you reinstall, connect it to a garden hose outside. No water should come out when you turn the hose on. If it still fails, just buy a new valve.
  1. Unplug washer, turn off water supply and remove hoses from the back of the washer.
  2. Remove the top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
  3. The water inlet valve will be located at the left rear of the washer (as viewed from the front).
  4. Remove the dispenser hose, electrical connections and mounting screws and the valve is removed.
  5. Install new valve by following these steps in reverse order. NOTE: When reinstalling top panel, make sure you lay panel on top of washer, leaving a couple of inches of room from the front panel. Then, slide panel towards you (front of washer) so that the top panel slides into the mounting clips.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
