Question about Fuji FinePix J12 Digital Camera
I am logging into finepix and i want to transfer pics onto my computer and i plug in the usb and then the camera and then turn on and then it makes the noise that the computer registers the device but doesnt think or say anything and wont bring up the pics. do i need to update the system to access pics. even though the program is already on my computer and it has worked before?
How do you transfer pictures from Fujifilm Z30 to Hp computer using USB cord? I searched this on another site but when I plug my cord in and turn on my camara nothting comes up and no pics. can be found in...
Connecting the camera to the computer requires that you install the software that came with the camera. If you didn't do that, you can still download your pics using a separate card reader. typrice_217.jpg
Jul 18, 2011 | FUJIFILM FinePix Z30 Digital Camera
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
I cant seem to get my finepix s5600 to transfer pics onto my pc. i bought it on e-bay and have not got a software disc. i have vista basic, can anyone help please, thanks.
The easiest way to transfer the images is to remove the memory card and put that into your computer (assuming you have the appropriate reader built in). Otherwise you should be able to copy the pictures by plugging the camera into your computer by USB.
Most models will be recognized like an external storage device and you should be able to transfer from that. Very rarely some cameras need to be set into a PC / transfer mode in the settings before transferring by USB.
Please leave feedback if this was helpful. Thanks!
Mar 25, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
How do i transfer photos onto my computer ?
you would be having a data cable provided with the camera... plug it in to the camera as well as the computer USB port. install the camera drivers (generally not needed) and you system would recognise the camera, after this you can transfer the images from the camera to the computer.
Mar 12, 2011 | FUJIFILM FinePix J40 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
Feb 05, 2008 | Fuji FinePix S700 Digital Camera
Fujifilm FInepix A500
Reconnect the camera to the computer. and then go through the closure sequence one more and do not unplug the camera untill you are told to do so. Aalso get onto the FUJI tech support team.
Jun 24, 2007 | Fuji FinePix A500 Digital Camera
Fuji FinePix J12 Digital Camera Logo
51 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
