Question about Samsung TV Remote Control
We just purchased a 32" Samsung LCD TV. WE love it, but we cannot get the remote to do anyting but increase the volume and turn it off. Our old remote which is part of the cable box does the channel select, etc. Is ther any way to get this done with just one remote?
    Sergeant:
  • 316 Answers
Program the cable box remote to your tv.
Posted on Oct 04, 2009
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
I have a 32 inch Samsung LCD TV. For some unexplained reason it keeps turning the volume down by itself. I have tried the obvious, like taking the batteries out of the remotes and then turning the volume...
Warning! Pull out the cord first!!! Open the TV take the tester and check over the mini board with the buttons, there might be the Vol- button in shortcut, or get some water. If its short, must replace, if there are water/ liquid/ oxyds traces, take a toothbrush, put a little of alcohol, and gently clean the place, after that dry it with a hairdryer.
May 18, 2011 | Samsung LN-T3253H 32 in. LCD Television
My samsung le32r74bdx remote control wont change channels and cant turn volume on tv up or down
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Feb 08, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung lcd 32 inches screen. The volume turns down to zero by itself. The remote control looses control. Control through remote control keeps coming and going intermittently.volume can be turned up...
Try removing the batteries from the remote after you set the volume, just to determine if the remote is causing the problem or not. I have seen stuff spilled on remotes and they just go crazy.
Feb 13, 2018 | Samsung LTN226W 22 in. HD-Ready LCD...
Greyish marks on Samsung 32'' LCD TV
it should be covered, can call 1-800-samsung for nearest authorized service center or go to samsung.com
Dec 31, 2009 | Televison & Video
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
Dec 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
No Sound on Samsung HDTV? But there is a picture...
Push the MUTE button on the TV remote to restore audio.
Nov 18, 2009 | Samsung LN-T3253H 32 in. LCD Television
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Sky remote
TV
RED + SELECT
TV
0056
press the volume button if it works press SELECT to save if not press TV again then volume repeat this step until the volume works remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Dec 27, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung TV Remote Control Logo
412 people viewed this question
Henry  Thomas
Henry Thomas
