Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Speakers have started popping / cracking - Mitsubishi Diamond WD-65831 65" Projection HDTV
At low volume it is fine after you get to about 20 on the volume it starts to crack,pop and distort very bad what is making this happen
Your speakers may say 350 watts but that is the peak wattage at which they blow up and not a wattage they can sound distortion free at. Look for the RMS wattage which is probably around 40 watts. If you look at the specs on your receiver you will see it will put out a maximum of about 50 watts but the distortion on the receiver is above 1 percent at anything over 22 watts. That means they are going to start distorting at around half volume. The other thing you might check for is a impedance mismatch between the speakers and the receiver. Is the receiver set up for an impedence output of 8 ohms but your speakers are 4 ohms impedance.
Aug 23, 2015 | Kenwood KDC248U CD Car Stereo Receiver...
How do i get my speaker to work at high volume with out them cracking,popping destort
If you are using the factory installed speakers they aren't made for the wattage output of your receiver. Factory stereos only put out about 5 to 10 watts. If you want to play it really loud you need to replace them with speakers that have a higher wattage that what your receiver puts out, which is a maximum of 50 watts
Aug 23, 2015 | Kenwood KDC-248U In-Dash CD, MP3, WMA Car...
Why is my Vizio VA320M HDTV making cracking and popping sounds?
Check the speaker first. If it is found OK, Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Apr 03, 2015 | Vizio VA320M 32 in. LCD HDTV
Because my rear speakers are popping and crackling during DTS output, I believe my settings of bass or treble might be overloading my speakers... should I set the rear speakers to "flat"? should...
Cracks and pops are dangerous. Can you tell if they might be circuit overloads or maybe digital decoding errors?
Are you routing bass to small speakers. THAT would definitely have audible problems. Define all of your speakers Large vs Small based on their bass-handling capacity.
ONLY DTS? Probably NOT the speakers or amps. How many sources are involved? Could be with the source or cabling.
Does it happen at low volumes, too? Then it would probably be digital in origin.
Do the indicators various digital surround mode indicators flicker or turn off when the pops appear?
As for the rest of your questions, I'd set everything at flat and start all over. If you're maxxing out any settings, something is wrong.
Jan 03, 2011 | JVC RX-7000V Receiver
"pop" in speaker when turned up
more likely your deck is just running out of power. another cause is the speaker leads could be hitting the metal of the car with the bass, check for clearance.
May 19, 2010 | Alpine SPS-609 Car Subwoofer
Popping and cracking noise from rt side speaker
You probably have a bad solder connection or an intermittent part failure in the right audio amplifier or its source circuitry. Put in a call for warranty service.
Dec 08, 2009 | RCA Televison & Video
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
