Question about Electronics - Others
Pen drive pblm
Im using this pen drive. im not be able to format / store date in my pen drive. pl advice
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Oct 04, 2009
    Genius:
  • 1,274 Answers
Drive may just be bad, have you inserted it and gone into command prompt and tried to format it that way?
Pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 14, 2009 | Kingston Technologies 512MB DataTraveler I...
Write protected
do you use windows vista or windows 7 OS?
They have a feature to use an external pen drive as a virtual system memory.
Try backing up all your data to your hard drive then full formatting it choosing NTFS system.
If you use OS which are older than Win XP, you need to format it in FAT32 system instead.
Hope this helps.
Sep 09, 2009 | Sony Electronics - Others
Pendrive has a file-CleanVirus.vbs...wat does it do...
Iam having a 4 gb Kingston make pen drive which is giving virus problem.ie clean virus.vbs when ever im inserting in comp. and trying to open or auto play the same message is appearing pl help me how to get rid off from this problem
Jun 09, 2009 | Samsung SGH-D900 Cellular Phone
File System of USB Pen Drive
You will not be unable to access your files on other computers because of the file permissions that go along with NTFS. I would recommend Fat32 if you are thinking of using those files everywhere you go, but stick with NTFS if you want the security.
Im not sure why the volume label appears in blue but im pretty sure its not virus related.
Dec 30, 2008 | Microsoft Windows XP Professional
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Pen drive malfunction
when i fix the pen drive to the PC it throughs a massage "USB devive not recognized"
Oct 16, 2008 | Transcend (589307) Media
8GB TRANSCEND PEN DRIVE - WRITE PROTECTION DELAYED - REMOVE WRITE PROTECTION
Use following link to download recover jetflash from transcend site.
http://www.transcend.nl/support/dlcenter...
note that the data on the pen drive will be erased. so back it up before you run it.
  • 1 week ago
Sep 16, 2008 | Electronics - Others
Pen drive is not working............
may be there is some kindaa virus affected your pen drive..
why dont you try it by once formatting it in some other system
or everywhere it says "plz insert the pen drive"
Mar 13, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Sonyns-11 mp3/wma/rec 1gb - memory loss
i have a phillips 2 gb mp3 and i lost all of its songs as they came with it it was new how do i get it back plz i wz crying man
Dec 28, 2006 | Pen Drive IVO MP3 Player
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
