Question about HP Deskjet 6940 InkJet Printer
Printer is only printing grayscale, need color, hp deskjet 6340
    Sniper:
  • 70 Answers
This is either because: 1. You only have black ink remaining and your tri-colour cartridge is empty or 2. In the printer driver settings you have selected either: Print Grey scale or Use black only.
I beleive your problem might be the last option.
To fix it :
1. Go to the printer driver (in vista go to: Start, Control panel, Printers, right click on your printer and select "printing preferences"). Now you are inside the printer driver. 2. go to the "color" tab. 3. Tehre you'll see if you have selected wither "Print in grey scale" and/or "Black only". 4. To ensure you get color again, de-select the"Print in grey scale" option.
Cheers, Ed
Posted on Oct 04, 2009
  • 137 Answers
Have you tried going into the printer properties? Sometimes the default is set to greyscale.
When you try to print, click on the properties button that shows beside the printer that is selected.
Navigate through the tabs till you find the color settings and choose colour.
If this solution has helped you, please take the time to rate me.
I have an HP deskjet 5650 and just changed both black and color cartridges. Test sheet ran fine with color and black. Now I am trying to print a Print Shop color document and the printer will only print...
Click Start
Click Control Panel
Click Classic View
Click Printers
Select your printer
Right-mouse click on the icon
Click Properties
Set the printer to print in "colour", not just "black".
Aug 30, 2010 | HP DeskJet 5650 InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
How do you print in GRAYSCALE on my HP DESKJET 3320? I cannot find the option or feature that allows me to do this.
There is no such feature in the printer. It can be done only from the word processor. Select the portion you want grayscaled and give it the right color. Print.
The printers will print whatever the word processor tells it to print.
Jun 15, 2010 | HP DeskJet 3320 InkJet Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
Color feature is turned off. Need to turn it back on.
Go to Start Menu, Printers and Faxes and right click on the printer, select Printing Preferences, go to color tab, and uncheck print in grayscale
May 16, 2009 | HP DeskJet 5150 InkJet Printer
My HP Deskjet D1430 won't print in color anymore
Try going to the printers properties page, go to the color tab, and be sure that "print in grayscale" is unchecked....keep me posted...
Mar 10, 2009 | HP Deskjet D1430 InkJet Printer
Hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Oct 18, 2008 | HP Deskjet 3845 InkJet Printer
HP deskjet printer D2460
Welcome to Fixya !
I assume that the printer is set to print in grey scale as below. follow the same procedure to change it to colour mode. If its still priniting in the Grey scale mode, Then please check the ink level in the printer.
Print in grayscale
To print in grayscale
1. Open the Printer Properties dialog box.
2. Click the Color tab.
3. Click Print In Grayscale.
4. In the Print In Grayscale drop-down list, select an option.
5. Select any other print settings that you want, and then click OK.
Apr 03, 2008 | HP Deskjet 2460 InkJet Printer
Colour???
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
345 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
