Question about Ultra Dragon ATX Mid-Tower Case
Need to know how to open for cleaning - Ultra Dragon ATX Mid-Tower Case
  • 137 Answers
There should be a handle on the side (opposite to mother board where everything plugs into the back). Simply squeeze the handle and pull the side back. If the case locks, make sure the case is unlocked prior to carrying out the procedure
If this solution has helped you, please take the time to rate me.
Posted on Oct 04, 2009
Lines in picture I think it needs to be cleaned How do I do this
it will have its own head cleaner program ,try this. click on the start bar ( bottom left of your screen ) open control panel,open devices and printers,look for your printer ( hp ** ) now RIGHT click on the name of your printer,go down to properties,left click to open properties, all your options will be in there for maintenance ( head clean etc )
May 20, 2015 | HP DeskJet Office Equipment & Supplies
How do I open fireplace to clean out
Great question but we need to know what you have
Dec 10, 2014 | Heating & Cooling
I do not know how to clean this fan. Do I need any tool for cleaning this fan? Thanks
generally a soft brush should work fine. Also if you have it compressed air will help. this can be doen without opening up the cage. but opening up the cage might make it easier
Aug 28, 2011 | Vornado VF20 Table Fan
Xbox 360 makes 2 vibrating weird noises then it say open tray and wont read the disk help please
Well it seems your eye in your disc drive is either damaged or need to be cleaned. Two ways can help you just send it in to Microsoft and they will clean it or fix the eye Or if you feel brave enough open it up yourself and manually clean with a cutip gently. You will need a guide it probably be best if you use youtube for guide. I dont recommend you open it though it could be bad if you dont know what your doing so, just send it in.
Aug 11, 2011 | Microsoft Xbox 360 Console
How do you know if a cooling condenser needs to be recharged?
Before you can answer that question the equipment must have clean evaporator, clean condensor, all fans working oiled and up to speed. Drain line in evaporator clean and opened. what refrigerant. let me know I can help. Thanks for choosing fixya. wally
Jul 29, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
Having trouble lighting a second hand efel oil stove what is the steps needed to take when igniting it
plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
Sep 13, 2010 | Heating & Cooling
(1)Cannot find location of model number. (2)Cannot locate service manual. (3)Need to clean oven. I believe the ovens (double/wall/electric) were installed in, or around, 2003, 2004. Simple want to know the...
need to know what model and brand you have.
most newer ovens only need you to remove the racks, then push the button for self clean, push the button to allow about a 3 hour clean cycle and it should then go into a lock the door mode. after the time is up it will need to cool down and then you should be able to open the latch and wipe out any burnt residues.
Dec 31, 2009 | Ovens
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Craftsman chainsaw runs wide open all the time
It sounds like the needle valve in the carburetor is stuck open. The carburetor could just need a simple cleaning or you may need a new carb. kit.
If the carb. parts (needle valve, gasket(s), diaphragm, & small screen) are more than 3 to 4 years old, you should go ahead and buy the carb. kit. Otherwise just clean the carb. If you need advice on how best to clean the carb., just let me know.
Jim
Jun 11, 2009 | Garden
GE Hotpoint electric stove
If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
Jan 22, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Ultra Dragon ATX Mid-Tower Case Logo
69 people viewed this question
Top Ultra Computers & Internet Experts
just-ice
Alun Cox
ed_coyle
ed_coyle
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
