Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
I bought a second-hand washer (whirlpool gu1000 series) Hooked up..lights come on ..can hear the water cycles operating..drains fine. But the motor dosen't sound like its working(no water being splashed around!?! Before I "rip" it back out..is there any way I can check the motor..
    Sergeant:
  • 316 Answers
You should be able to pop the top of the agitator off. There are sometimes plastic gears right there that get eaten away. Check those.
Posted on Oct 04, 2009
Maytag Whirlpool Super Capacity Ultimate Care Washer, it goes through all the cycles except the spin cycle. Will not spin.
Most likely the lid switch or the motor coupler. Is it just doing nothing when time to drain and spin leaving it full of water? If so, replace lid switch. If it's pumping water out and you hear motor running, but it's not spinning, then motor coupler is most likely broken. In second scenario, also could be clutch or other transmission problem.
Oct 31, 2017 | Whirlpool Washing Machines
Does not Wash
first check if there was an object that obstruct the motor, try to clean that area, and run again the unit, if the problem was still there, then could be the washer motor was broke.
Aug 07, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
Sep 02, 2014 | Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
    Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
    Sep 01, 2009 | Kenmore Washing Machines
    Washing machine fills, agitation fails
    Problem solved. The short version; there was a toddler's sock stuck in the water pump. Once removed, the machine works great.
    FYI - After I removed the outer casing, to drain the water, I removed the BOTTOM hose from the pump first (TOP hose was unrestricted flow and my spill pan under the washer wouldn't have been able to keep up with the volume). The water trickled out steady and slow, which made me think 'obstruction.' Once the water drained, I pulled off hose #2 and there was the sock. The motor turns both the transmission (agitation/spin cycles) and the pump. The blocked pump was preventing the motor from turning, and the safety mechanism was kicking out so as to prevent the motor from burning up. I checked the motor and transmission while I had it apart, just to verify these other parts could move on their own and had no issues. They were fine. There's something to be said for these older washers ... even a 'no experienced idiot' like me can figure out how it works. Hope this is helpful to someone else out there.
    PS - The hardest part was getting the washer casing back into place.
    Jun 29, 2009 | Whirlpool Washing Machines
    Front loader with F02 problem
    CHECK THE DRAIN MOTOR PUMP it could be clogged, need to open washer , locate drain motor , youll see the drain hose connected to it , inspect , clean and replace , AJ
    May 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Washer - Imperial Series Quiet Wash 2
    your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
    Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Cabrio WTW6600SW1: Won't drain
    The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
    Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
    150 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
